Old 01-08-2008, 12:31 PM   #3211
Why do you only want to use CVD's in the front? Other comparable cars come with all four.
92mnstanger is offline   Reply With Quote
Old 01-08-2008, 12:36 PM   #3212
Team Kamikaze's Avatar
Because there is no real advantage of using a rear cvd's.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 01-08-2008, 12:58 PM   #3213
Doesn't the wheel axle get worn due to the clearance between the axle and the dog bone?
What's the advantage in front? Retention of the axle after a crash?
Old 01-08-2008, 01:38 PM   #3214
It will, but it's going to be a while.
Old 01-08-2008, 02:03 PM   #3215
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
CVD's also make the drive train smoother
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 01-08-2008, 02:30 PM   #3216
So why would there not be an advantage to rear CVDs? Going from throttle to brake will change the side of the axle that sees force. Any slop in this transition can shock the rear tires on initial braking...Or am I nuts?
Old 01-08-2008, 02:47 PM   #3217
It's not to say that you can't use them its more preference and parts. I'm running cvd up front and dog bones in the rear,if you decide to run cvds in the rear you won't have any problems just make sure to check them occasionally to make sure their not bent. Hope this helps.
Old 01-08-2008, 05:37 PM   #3218
djgoku's Avatar
Default Increase 720 Ratio similar to the V-one or Mugenīs
Hello!
Been racing in a technical racetrack with lots of turns, V-oneís and Mugenīs are eating me on the turns I have to compensate with the smaller gears possible.
Iíve calculated the drive ratio of the serpent and itís:
Front 1.92, Rear 1.95 to my understanding great on mid to large tracks, also calculated Ratios in other cars and they are over 2.00
Just saw on Serpent USA the Overdrive conversion set 720 18T (#803202).
If I calculate the New ratios:
Front (35/18)*(22/21)=2.037
Rear (47/24)=1.9583
They are to far to obtain near 2.03
If I had a 23T Iíll had:
Rear (47/23)=2.043
Close enough
Can I convert any serpent 23T pulley to the Serpent 720 Brake pulley?
Like the one on the F180 Pulley 23T (#301053)
Anyone knows if other brands pulleys are compatible with 720?
Any of you guys have some ideas to increase Ratio similar to the V-one or Mugenīs (around 2.00)
Tankyou
djgoku is offline   Reply With Quote
Old 01-08-2008, 07:19 PM   #3219
nigelnuggets's Avatar
Send a message via AIM to nigelnuggets
Originally Posted by djgoku View Post
Hello!
Rear (47/24)=1.9583
Rear (47/23)=2.043
Close enough
Tankyou
Overdrive ratio change is specifically for the FRONT overdrive. As in, # of rotations of the front tires versus the rear tires.
Youre looking to change the INTERNAL ratio.
Kamikaze Toys and Hobbies. www.kamikazetoysandhobbies.com / www.kamikazercracing.com
nigelnuggets is offline   Reply With Quote
Old 01-08-2008, 07:21 PM   #3220
If you want a 23t that may possibly fit on the Brake Hub adaptor, you can look into this pulley. Part no. 808228
Old 01-08-2008, 09:02 PM   #3221
Derby Bros Racing's Avatar
Hello!
Rear (47/24)=1.9583
Rear (47/23)=2.043
Close enough
Tankyou
Are you talking in terms of acceleration?
The internal ratio is affected a lot with your main gearing (pinions and spurs). Changing to smaller pinions will gain accelaration if that is what you are looking for. Changing the pulleys will affect your overdrive. The car in stock form is almost 1:1 with a 0.5mm split between front and rear tires.
If you are looking for more turn in and quicker speed in turns, you may want to raise your rear roll center.
Derby Bros Racing is offline   Reply With Quote
Old 01-09-2008, 05:41 AM   #3222
dj apolaro's Avatar
How long is your straight? I have done a lot of testing with internal drive ratios and can help if I know how long the straight is. Also what kind of motor?
DJ Apolaro
dj apolaro is offline   Reply With Quote
Old 01-09-2008, 10:52 AM   #3223
Even with the smallest pinion and biggest spur, it is possible that the car cannot achieve the same acceleration as a car with a higher internal ratio. Changing the brake pulley and differential pulley's tooth count allows us to change the internal ratio which can then increase or decrease acceleration as well as theoretical top speed. By changing the pulleys else where, this affects the overdrive ratio ie. 2sp side pulley, side pulley, middle shaft pulley and 1 way pulley.
Old 01-09-2008, 10:58 AM   #3224
You are absolutely correct. I've seen a racer change his pulleys (for internal ratio not overdrive) and he was able to use stock pinions and still get the acceleration of 16T. We race on a very small track but fortunately, 16T was enough and I like the fact that they are available in steel .
How have you been Nigel?
Our local onroad scene here is not doing very good at the moment. It looks like I have to drive there just to run onroad.
Old 01-09-2008, 10:59 AM   #3225
You're tellin me man, Our tracks are dissapearing one by one. CP has some issues, GLARCRC is only open when the city says so. Im stuck running EP Touring. And you know me, 1/10th + my fingers dont mix. LOL
Anyway, the S400 is extremely good, it has capabilities to win around here, i just need to practice lol.
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
