Serpent 720
Old 12-17-2007, 11:21 PM
  #3136
can someone please explain which are the softer to harder in the new spring
FITO is offline
Old 12-17-2007, 11:54 PM
  #3137
kitracer's Avatar
I am back with 720 for next 6 weeks getting ready for the Serpent Nitro Tour.
Julius, hope to see you in Hong Koing
kitracer is offline
Old 12-18-2007, 12:25 AM
  #3138
Simon M's Avatar
New Spring ratings
N/mm lb/inch
White 2,3 13,0
Yellow 2,8 16,0
Orange 3,4 19,5
Red 4,1 23,5
Pink 4,9 28,0
Blue 5,8 33,0
Purple 6,8 39,0
Green 8,0 45,5
Grey 9,0 51,5
Black 10,0 57,0
Old spring ratings
REAR N/mm FRONT N/mm
Orange 2,1 Orange 2,7
White 3,0 White 3,0
Yellow 3,8 Yellow 4,0
Red 4,6 Red 5,0
Blue 5,2 Blue 6,1
Purple 6,2 Purple 6,5
Grey 10,9 Grey 10,3
Simon M is offline
Old 12-18-2007, 06:46 AM
  #3139
dj apolaro's Avatar
The way they are listed is the soft to hard.
New Spring ratings
N/mm lb/inch
White 2,3 13,0
Yellow 2,8 16,0
Orange 3,4 19,5
Red 4,1 23,5
Pink 4,9 28,0
Blue 5,8 33,0
Purple 6,8 39,0
Green 8,0 45,5
Grey 9,0 51,5
Black 10,0 57,0
DJ Apolaro
dj apolaro is offline
Old 12-18-2007, 08:51 AM
  #3140
thanks but i dont get it. the older spring were measue by diameter of the spring such 1.4mm thick to 2.0mm thick. the new ones have a rating that i dont understand.
FITO is offline
Old 12-18-2007, 10:05 AM
  #3141
Sow&Steady's Avatar
The new ones are rated by compression; Newtons per mm compressed or pounds needed per inch compressed. Its more meaningful and consistent this way rather than thickness of the coil because there are no proper standards for the actual coil/spring materials. Just my 2 cents.
Sow&Steady is offline
Old 12-18-2007, 10:53 AM
  #3142
dj apolaro's Avatar
The new springs are easier to understand. It also helps with comparing notes on all springs. most of the companies use a compression rate. I like the new way of reading the springs, although it will take some getting used to.
DJ Apolaro
Old 12-18-2007, 12:11 PM
  #3143
Serpent-Dan's Avatar
Trader Rating: 18 (100%+)
Hey DJ which color of the new springs have you been using.You didn't put the springs on your last setup.
Serpent-Dan is offline
Old 12-18-2007, 12:18 PM
  #3144
dj apolaro's Avatar
I still use the old springs out of habit. I am going to start using the new springs at the next race. Most likely front blue and rear orange or red.
Regards,
DJ Apolaro
Old 12-18-2007, 12:21 PM
  #3145
You also stopped using the zx engines, nova power now.
Old 12-18-2007, 12:37 PM
  #3146
rcpanama's Avatar
Yesterday I race and used Red 27mm in the rear and Pink 23mm in the front, they work perfect with 40 tire front and rear, this was in a mid to low traction parking lot track.
I finish third, the card was handling excellent.
RCPANAMA
rcpanama is offline
Old 12-18-2007, 12:55 PM
  #3147
dj apolaro's Avatar
Yes, I am very happy with my Nova's
Old 12-18-2007, 01:15 PM
  #3148
Yeah I'm thinking about switching to a nova or rb r3 but my sponsor (my wallet) is being cheap at the moment..
Old 12-18-2007, 01:20 PM
  #3149
Registered User
Derby Bros's Avatar
Originally Posted by Team Kamikaze View Post
The 08' 720 kits are now available, it comes with a lot of goodies and the price is low considering the option parts that came with it.
Do you also have the new springs instock?
Derby Bros is offline
Old 12-18-2007, 01:33 PM
  #3150
Team Kamikaze's Avatar
Yes always!
Team Kamikaze is offline
