Serpent 720
Old 12-10-2007, 05:36 PM
  #3121
bobbyblaze's Avatar
this my first time using a centrax clutch what the proper way to adjust it with the caliper just alittle confuse
blaze
bobbyblaze is offline
Old 12-10-2007, 07:04 PM
  #3122
dj apolaro's Avatar
Originally Posted by Doug M View Post
Congratulations DJ, great job, you are on a roll! Will we see you at the Bring a Toy Christmas Challenge this saturday?
Also a shout out to Luke Whitaker, Austin Wolfe and Gianni Giorgio. Good going guys!
I can not make it this saturday, sorry. I have to get ready for the holidays. Good luck and hopefully I can do it next year.
DJ Apolaro
dj apolaro is offline
Old 12-10-2007, 10:00 PM
  #3123
thank you Doug
see you there
ciao
gianni
serpentmaster is offline
Old 12-11-2007, 05:12 AM
  #3124
Default info on the new AFL cap seal
Hi guys,
Regarding the new AFL cap seal, from what i understand old tank can be use, just need to measure for compatibility but does it need a new type cap or just with a o-ring type cap or the old foam type cap??
thanks
ck960 is offline
Old 12-11-2007, 02:14 PM
  #3125
roadrage's Avatar
Trader Rating: 14 (100%+)
hey doug thank you. hopefully well see you this weekend!
roadrage is offline
Old 12-11-2007, 07:15 PM
  #3126
Why thank you Doug.
Luke W is offline
Old 12-12-2007, 05:22 AM
  #3127
Default hi
hi my friend, good job....
ciao
gianni
  #3128
Originally Posted by Luke W View Post
Why thank you Doug.
congrats Luke, very well
see you
gianni
Old 12-12-2007, 09:58 AM
  #3129
Team Kamikaze's Avatar
Originally Posted by Jo Gutierrez View Post
Cool! Don't forget to post here when you get some instock .
It is available NOW!!!
Team Kamikaze is offline
Old 12-12-2007, 05:51 PM
  #3130
Anybody having problem with new 23 mm spring set being too short on the rear shocks? I have the spring collars all the way down to get the ride height with 62mm rear tires. As the rear tires wear, I have no more adjustment.
RoyU is offline
Old 12-12-2007, 07:29 PM
  #3131
Simon M's Avatar
The 23mm springs are for the front only
you need the 27mm springs for the rear
Simon M is offline
Old 12-12-2007, 08:04 PM
  #3132
rcpanama's Avatar
It is correct the 27mm will solve that problem, but I did the same as RoyU, because if you read the information from Serpent it says that the 23mm are to be used for 1/10 in front and rear, I had to order then the 27mm to correct this problem.
“Serpent has released 2 sets of new series shock springs, which are suitable for use with all current and previous Serpent shock absorbers. Sold in sets of 5 pairs of springs, 1 set contains 23mm length springs, 1mm longer than the older version, for the front of 1/8th scale chassis’ and both the front and rear of 1/10th scale chassis’, while the 2nd set contains 27mm springs for the use on the rear of 1/8th scale chassis’. Featuring a new colour rating these new series of springs are of a better quality, coming with ground flat ends, and as they no longer have a colour coating they function more accurately. The spring’s hardness is now identified by the coloured paint on the springs tip.”
rcpanama is offline
Old 12-12-2007, 08:50 PM
  #3133
These work great for that situation.
http://www.serpent.com/product/903240/
neltime64 is offline
Old 12-13-2007, 09:33 AM
  #3134
I thought about the higher cups, but I think I'll still run out adjustment.
Anyway, I have the long spring set on order
RoyU is offline
Old 12-17-2007, 10:14 PM
  #3135
The 08' 720 kits are now available, it comes with a lot of goodies and the price is low considering the option parts that came with it.
