Old 11-13-2007, 09:30 AM   #3061
Thumbs up
Originally Posted by dj apolaro View Post
The car was good. In the main we ran in the dark and I can not race in the dark. I just keep it on the track and stayed out the way.
Congrats on A-Main finish....
Can you post your setup?
James "Nel" Nelson
SpeedWorld Raceway & Hobbies | DesotoRacing.com | R1 Wurks
neltime64 is offline   Reply With Quote
Old 11-13-2007, 04:21 PM   #3062
Congrats to DJ for the excellent result. Too bad with the wheel nut, but next time my friend. You look good the whole event. We are proud!!
Congrats to Maxy, 2007 Master National Champion. You deserved it my friend. Thanks for give us and the S-720 another national champion!!! Way to go!!
Will like to thank all the Team for their hard work. Yo know who you are....
Paolo M is offline   Reply With Quote
Old 11-14-2007, 09:27 AM   #3063
Default thanks
Well guys, back in miami, impossible to be more happy whith the results in the nationals. I want to thank serpent usa for their support. Paolo thank you. Gianni your the man, the best pitman i could ever had thanks a lot. Rafael thanks to keep me in the good line talking to me from the pits, everything went out perfect, thanks a lot to every one who was there supporting me and once again congratulations to team serpent usa keep the good work.
maxy is offline   Reply With Quote
Old 11-15-2007, 06:42 PM   #3064
Paulie Bee's Avatar
Felicidades Maestro Maxy El Tigueron.
Estoy tan orgulloso de ti! See you soon Dec 7-9 Kissimee and W'Nats too....
Paul
Paulie Bee is offline   Reply With Quote
Old 11-16-2007, 08:04 AM   #3065
dj apolaro's Avatar
Give me a couple of days and I will put it here for you.
DJ Apolaro
dj apolaro is offline   Reply With Quote
Old 11-16-2007, 10:18 AM   #3066
Derby Bros Racing's Avatar
DJ you got PM
Derby Bros Racing is offline   Reply With Quote
Old 11-16-2007, 10:35 AM   #3067
dj apolaro's Avatar
Originally Posted by Jo Gutierrez View Post
DJ you got PM
I replied.... hope it helps.
Old 11-16-2007, 11:07 AM   #3068
Thanks!
Old 11-16-2007, 11:08 AM   #3069
DJ Apolaro
James "Nel" Nelson
Old 11-16-2007, 12:27 PM   #3070
dj apolaro's Avatar
2007 Nationals set up
front
lock
35wt 2 hole piston, very little rebound
purple springs layed down
-2 droop
5 ride height
38 shore 57.5mm
pins in upper position for roll center
2mm caster in front
-1 toe on each side
soft front bar and flat
Rear
20,000 diff oil
35wt 3 hole piston, very little rebound
yellow springs 3rd position from bottom
4 droop
6.5 ride height
40 shore 59mm
#3 position roll center
upper link at its shortest and most angle
2.3 sway bar inner position on bottom
2.5 rear toe
I used the brass battery tray, and added 40 grams to my car. This brought me to 1740 grams. I ran a Nova 353 and 25% Maxy fuel. If I am missing anything, just ask.
Regards,
DJ Apolaro
Old 11-16-2007, 07:03 PM   #3071
Simon M's Avatar
anyone know where i can get a soft front roll bar
Serpent 960
Serpent 720
Serpent S400
Serpent S120
Tamiya M03-R
www.serpentradiocontrolcars.com.au
www.smaracing.org
Simon M is offline   Reply With Quote
Old 11-16-2007, 07:04 PM   #3072
Gael L's Avatar
front
lock
-2 droop
5 ride height
38 shore 57.5mm
2mm caster in front
-1 toe on each side
Rear
20,000 diff oil
4 droop
6.5 ride height
40 shore 59mm
2.5 rear toe
Regards,
DJ Apolaro
interesting setup. did you go with -2 droop in order to gain some traction in the rear?
Gael L is offline   Reply With Quote
Old 11-16-2007, 07:10 PM   #3073
dj apolaro's Avatar
The front soft sway bar is an option part. Look online at any of the stores that carry serpent.
-2 droop was not done for rear traction. It was more for the bumps.
Old 11-16-2007, 07:36 PM   #3074
Garaski's Avatar
Does your setup revolve around how much droop you want to have on the car ? When do you measure droop ?
Garaski is offline   Reply With Quote
Old 11-16-2007, 08:46 PM   #3075
dj apolaro's Avatar
Not sure if I understand the question, but I measure droop on the blocks. As far as the droop in relation to the set up, the set up of the entire car is a give and take. I normally do not use that much droop, but found it worked at the nationals for the bumps. Since I was using a hard front spring if helped soak up some of the bounce in the car. Hope this helps. I think I confused myself. haha
DJ Apolaro
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
