Serpent 720
Old 10-04-2007, 08:59 PM
  #2956
Just got my 720 07 in....going to start putting it together soon....now just need to decide on a good motor and pipe.
stylinhonda is offline
Old 10-08-2007, 08:09 AM
  #2957
hi guys;
I've just instaled the new afl tank on my 720 but it leaks a lot. It is the first thing that I bought from serpent that is realy two thumbs down .I haven't had this issue on the previous tank.
Does anyone have this issue? How can I fix it? Is it possible to remove the seal from the previous tank and install it on the new tank cap?
thanks and regards
Eduardo
eduardo_garcia is offline
Old 10-08-2007, 08:23 AM
  #2958
dj apolaro's Avatar
Originally Posted by eduardo_garcia View Post
hi guys;
thanks and regards
Eduardo
You can still use the old style foam seal. They still sell them from serpent. I personnally do not ue the new afl seal.
dj apolaro is offline
Old 10-08-2007, 08:43 AM
  #2959
Team Kamikaze's Avatar
hi guys;
thanks and regards
Eduardo
Before using the new tank with the O-Ring seal, you should let the Lid with the O-Ring seat in the tank overnight, that way the neck of the tank will conform to the new O-Ring, we never have problem by doing this procedure
Team Kamikaze is offline
Old 10-08-2007, 11:01 AM
  #2960
suck_my_exhaust's Avatar
Guys Im having problems with the 2 speed gear on my 720.It doesn't wanna shift.I've set it up properly according to the manual and it won't change gear.How much tension can I loosen it?Anyone has the same problem?Please advise...Thanks.
suck_my_exhaust is offline
Old 10-08-2007, 11:15 AM
  #2961
dj apolaro's Avatar
The stock point is not tight enough. It is most likely shifting immediately. tighten it one full turn on both sides and check it. Then start backing it off little at a time till you have it the way you want it.
DJ Apolaro
Old 10-08-2007, 11:23 AM
  #2962
DJ Apolaro
No wonder my car seem to accelerate slowly and the engine felt like its got no punch at all.Thanks for the advise..appreciate it very much.
Old 10-08-2007, 11:41 AM
  #2963
dj apolaro's Avatar
Old 10-09-2007, 01:28 AM
  #2964
Hi Guys
I had the same problem with the AFL lid at first. Problem was that the lid did not close properly. Then I used a screwdriver and pushed the entire mechanism closer to the lid and now it closes properly. Since then, no problem...
Acid
Acid is offline
Old 10-09-2007, 08:36 AM
  #2965
Geezatec's Avatar
Sluggish cuz it is in second gear. Have to adjust the 2sd. Turn the 2sd shoes 2 screws a 8th turn til it shifts. The 2 screws you turn are the 2 that has spring or 2mm allens. Adjustment of pre-asemble is very loose, It stay in second gear. Just take your time in adjustment. Once you get it, Have fun Racing.
Geezatec is offline
Old 10-12-2007, 12:28 AM
  #2966
Bambusratte's Avatar
Questions?? New Xray shocks on Serpent 720?
Hello,
does anybody know if the new Xray shocks fit the serpent 720? Would be nice to run adjustable shocks again
Bambusratte is offline
Old 10-12-2007, 01:05 AM
  #2967
MHarrison's Avatar
They are the same as the 710's , so yes they will fit.
MHarrison is offline
Old 10-22-2007, 12:26 PM
  #2968
dj apolaro's Avatar
For any of you traveling to the Kissimmee race this weekend, good luck and safe travels. I will be there on Friday and will help anyone in need. Just come look for me and if I am not busy I will lend a hand. The track is a flowing track with good traction and low tire wear. See ya there!!!!!
DJ Apolaro
Old 10-22-2007, 01:02 PM
  #2969
Derby Bros Racing's Avatar
Good luck DJ
Derby Bros Racing is offline
Old 10-22-2007, 01:04 PM
  #2970
dj apolaro's Avatar
