Serpent 720
Old 08-20-2007, 09:37 PM
  #2821
Derby Bros Racing's Avatar
Originally Posted by old-man View Post
Has anyone tested the new steering blocks? Any feed back? Which hobby shop has them that I can buy online.
OM
Try contacting www.kamikazercracing.com . They are normally updated with parts and latest gizmoz and such. If they don't have it, try Winner's Circle. I'm with you on the performance question as I haven't tried them yet .
Derby Bros Racing is offline
Old 08-21-2007, 04:07 AM
  #2822
dj apolaro's Avatar
OM
I am currently running the new blocks. I have only run the 0 offset, but they are nice. They are made of stronger material and I feel like they give more mid corner steering. I hope to try the 1mm off set this weekend end.
dj apolaro is offline
Old 08-21-2007, 12:37 PM
  #2823
1FastSerpent's Avatar
So does this mean you are blessing us with your presence @ the Fort.
I finaly got a good Diff setup that fits my style. Will be fun to compare it with yours & see if it is faster then the oneway. Oh..gimme a call when ur not busy.
1FastSerpent is offline
Old 08-21-2007, 03:18 PM
  #2824
dj apolaro's Avatar
Old 08-21-2007, 08:00 PM
  #2825
roadrage's Avatar
Trader Rating: 14 (100%+)
oh great. marks running the diff!
roadrage is offline
Old 08-21-2007, 08:11 PM
  #2826
thamjk's Avatar
Originally Posted by Insane rc View Post
The 16t steel 1st gear won't fit verry wel unles you modifi the holes in the
chassi plate . otherwise the engine is not in line whit the spur gears.
It was intended for the 710.
NO ... same goes to 710... it can't be used either.
I have tried the 2nd speed off 55/20 but still can't get aglin.
thamjk is offline
Old 08-21-2007, 08:25 PM
  #2827
thamjk's Avatar
Originally Posted by rangulo View Post
This is not the correct reason why we do not use the 16t. The pitch of the 16t is wrong and will burn up the spurs. If you want to put a new 16t every run then it will be o.k..... We only run the 17,18 1st and the 22,23 in 2nd..
Rafael
the 16T alu pinion works well with 59T spear. 60T and 61T wear very fast.
The best I usually use on my 710 is 17/59. It last the most longest runtime.
But you are runing 6.5 gear ratio so the centex clutch and engine play the most role on the acceleration.
Thats is why 720 doesn't have any issues with 17/59 futhermore with higher internal ratio.
thamjk is offline
Old 08-22-2007, 10:30 AM
  #2828
Austin, Are you and the fellas coming down to the fort This weekend? It would be a 720 invasion.
Old 08-22-2007, 02:46 PM
  #2829
roadrage's Avatar
sure thing. me and ab. bobby says hes going and petes thinking about it. dont be to fast i might not want to come back
roadrage is offline
Old 08-23-2007, 03:34 PM
  #2830
rcpanama's Avatar
Default Ventilated brake disc 1/10th (#803213)
Hi, I just received the new ventilated brake disk; the package comes with three small rings, the rings (washers) are the size of the ventilated holes in the disk.
Any body can give me an idea what is this for
RCPANAMA
rcpanama is offline
Old 08-23-2007, 03:50 PM
  #2831
Sow&Steady's Avatar
RCPANAMA
Probably to shim the brake disk so that its nicely centered between the brake pads?
Sow&Steady is offline
Old 08-23-2007, 03:53 PM
  #2832
dj apolaro's Avatar
Maybe it is to space out the side plate. It takes 3 screws to it. Just a though. I have not seen one so not sure.
DJ Apolaro
Old 08-23-2007, 04:48 PM
  #2833
rcpanama's Avatar
DJ Apolaro
That could be it makes sense thanks
rcpanama is offline
Old 08-23-2007, 09:18 PM
  #2834
DENNIS STORTI's Avatar
Trader Rating: 42 (94%+)
i thought it was a new brake disc its ventilated an crossed drilled on the ends the trickest part i ever seen
DENNIS STORTI is offline
Old 08-23-2007, 09:26 PM
  #2835
new brake disk works great
the 3 washers are to space the carbon plate to compensate the thicker size rear brake
Jeff Cuffs is offline
