Old 07-22-2007, 07:05 PM   #2761
impalabob64's Avatar
Send a message via AIM to impalabob64
Thumbs up Rear oneway
I run it an love it
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 07-22-2007, 07:24 PM   #2762
rcabj's Avatar
anyone tried the option 18t pulley up front? how does it effect overall?
can anyone assist me for base setup for low traction + small/medium size track....TQVM
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 07-24-2007, 11:26 AM   #2763
ferfelu's Avatar
Default Adjustable Ackermann
Dear all,
I recently bought a 720 07 and everything went fine with assembling the car.. But when it came to setup, i couldn't find any ware in the SETUPBOOKLET the effect on setting up the Ackermann for the 720 07..
Could anybody pls give me some info or show me where in the post where I can find some info on the effect of adjusting the Ackermann..???
Ray
From the beautiful island of Curacao
ferfelu is offline   Reply With Quote
Old 07-24-2007, 12:44 PM   #2764
rmdhawaii's Avatar
Originally Posted by ferfelu View Post
Dear all,
Ray
This might help...
http://www.rctech.net/forum/showthre...18#post3421818
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 07-24-2007, 06:50 PM   #2765
ferfelu's Avatar
Originally Posted by rmdhawaii View Post
Thanks rmdhawaii.....
Ray
Old 07-25-2007, 12:09 AM   #2766
RevMaxx's Avatar
Send a message via MSN to RevMaxx
any of you guys know where i can find 16T steel 1st gear pinion for the
S720? i can't seem to find them at all the lhs near me, or even in the web...
any help would be appreciated.
RevMaxx is offline   Reply With Quote
Old 07-25-2007, 12:50 AM   #2767
Any news on the lipo receiver battery for the 720?
RoyU is offline   Reply With Quote
Old 07-25-2007, 04:20 AM   #2768
Insane rc's Avatar
The 16t steel 1st gear won't fit verry wel unles you modifi the holes in the
chassi plate . otherwise the engine is not in line whit the spur gears.
It was intended for the 710.
Insane rc is offline   Reply With Quote
Old 07-25-2007, 05:18 AM   #2769
Sow&Steady's Avatar
This is true, you should not need the 16t with the 720.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 07-25-2007, 06:16 AM   #2770
Hi!
I have a couple of them, if you are interested send me a PM.
Edgar Millenium is offline   Reply With Quote
Old 07-25-2007, 07:26 AM   #2771
This is not the correct reason why we do not use the 16t. The pitch of the 16t is wrong and will burn up the spurs. If you want to put a new 16t every run then it will be o.k..... We only run the 17,18 1st and the 22,23 in 2nd..
Rafael
rangulo is offline   Reply With Quote
Old 07-25-2007, 08:21 AM   #2772
RevMaxx's Avatar
reason for wanting a 16T steel is the wear of the pinion. spur is kinda eating it faster than i thought it would (weird, plastic chewing alum. - ). maybe its my mesh but its the best i could do.
i know its kinda normal - the pinion wear, and steel even gives me a disadvantage coz it will have more rotational mass due to steel weight than alum. but for weekend runs, i think the steel will be more of an advantage to me
hey edgar, you've got pm...
Old 07-25-2007, 08:39 AM   #2773
X1 Hybrid T1's Avatar
Rafael
I run the 16 quite often, and have never had gear trouble. I have used it on my 710 & 720 with no problem. Winners Circle (gasrccar.com) usually has them in stock.
Dave
We don't stop playing because we grow old;
We grow old because we stop playing!
Dave Steen ROAR #5692
Serpent 720,710,9020, Xray T1-05
Jammin X1-CR,CRT,CRT.5,Asc T4,Losi XXX4
X1 Hybrid T1 is offline   Reply With Quote
Old 07-25-2007, 12:23 PM   #2774
Dave
Well the 16 usually is worn out by the spur. The spur then has the gap increase and then rips through the spur after it looks like the saw blade. I personally do work on a lot of motors and have had that experience every time we use it. The new drive train of the 720 has been re worked from the 710 so the 17t is like running a 16t. A 7.0 final drive(17t pinion and 61t spur) for first is this pretty high and for most track is way more than sufficient. If you need more torque you need to look at the clutch setup your running. Any good clutch setup will wear the pinion and then cause a failure...
Novarossi clutch -yellow shoe (clutch bell gap .80) 1/8th spring Silver 1.4mm tighten down, standard weights.. Softer clutch decrease the gap from .8 to .7...
zx12 mega picco- yellow shoe (clutch bell gap .70)1/8th spring Silver 1.4-1.6 tighten down , standard weights... Softer clutch decrease the gap from .7 to .6
Old 07-25-2007, 08:04 PM   #2775
nigelnuggets's Avatar
Send a message via AIM to nigelnuggets
Whats up rafa, see you in vegas soon?
Kamikaze Toys and Hobbies. www.kamikazetoysandhobbies.com / www.kamikazercracing.com
nigelnuggets is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
