Old 07-11-2007, 09:37 AM   #2731
The Teacher's Avatar
Trader Rating: 48 (100%+)
When running the CVD's up front do you need to sand them down any? Also, I can't seem to get my shocks to seal correctly, do you guys have any tips that might help me??? I think I might be overtightening them.......I have purchased the alloy inserts so maybe this might help....
The Teacher is offline   Reply With Quote
Old 07-11-2007, 11:06 AM   #2732
rcabj's Avatar
Originally Posted by rc_alan View Post
If you're running cvd's up front, always have an extra pack on hand... Also, you may want to get the front lola bumper plate and the extra wide front foam bumper pad... Your front end will almost be bullet proof then. In the year that I've had the car, I've only had the replace a couple of cvd's and the front belt... Other then that, the car is rock solid!!! Remember though that anything can happen at the track so always have extra spur gears, arms front and rear on hand... .02
RC_Alan
thanks alan,any issues regarding the knuckles
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 07-11-2007, 03:19 PM   #2733
If you leave your front end stock, you will blow through front arms and knuckles if you take a hard hit on something... Use the lola front bumper plate and the extra wide foam bumper pad, your front end should be pretty much set and bullet proof... The rear end lower arms I was told are being updated by Serpent... as the 2006 batch were alittle weak. If you take a rear end hit from another car, those are the first to go... Sooooooo... Never race or practice with bad driver's that are looking to take your car out.. and if you're on the track that is full of 1/8 scale hackers... Wise thing is to pull your car off the track. .02 And no, not all 1/8th scale drivers are hackers... Just those that can't drive yet and can't handle the speed... Amen
RC_Alan
rc_alan is offline   Reply With Quote
Old 07-11-2007, 04:28 PM   #2734
Ffejdat's Avatar
For anyone running the Universals- you can get just the "bones" from Serpent for these, makes them a little cheaper to replace, part#802351... I would also recommend in your spare parts, to have the rear lower hinge pins, and the roll center inserts for the rear, they tend to get bent, or lost in a crash, cheap to stock one or two....
Ffejdat is offline   Reply With Quote
Old 07-12-2007, 10:30 AM   #2735
typer's Avatar
Here is my serpent 720 '07. Sorry for the poor quality of the pictures. I just installed lightweight clutch bell, alu pulleys, alu mid bearing block and shaft.
Serpent 720-dsc00009.jpg   Serpent 720-dsc00010.jpg   Serpent 720-dsc00020.jpg   Serpent 720-dsc00021.jpg
typer is offline   Reply With Quote
Old 07-12-2007, 03:37 PM   #2736
Sow&Steady's Avatar
Nice, congratulations ... you won't regret having it!
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 07-12-2007, 08:00 PM   #2737
ianhobbies's Avatar
Location: Costa Del Sol, Marbella, Spain www.bradir.net
Send a message via ICQ to ianhobbies
Default typer
bradir! nice pics!! see you at the boss bday race on the 21st!
WWW.BRADIR.NET - The Radio Control Motorsport Blog! / twitter @ianhobbies
ianhobbies is offline   Reply With Quote
Old 07-13-2007, 07:45 AM   #2738
rcabj's Avatar
just asking, anybody has any issues with the thrust bearings?
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
Old 07-13-2007, 09:45 AM   #2739
typer's Avatar
Try to get there on time bradir...open pa kc shop ko.tnx
Old 07-13-2007, 10:16 AM   #2740
typer's Avatar
Set your clutch gap properly
Old 07-13-2007, 10:26 AM   #2741
Team Kamikaze's Avatar
Why? What kind of problem are you having?
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 07-13-2007, 10:37 AM   #2742
rcabj's Avatar
actually none....for the past 3 years i only blown 1 piece only regardless of whatever make just that i'm still new with d 720... and someone told me the kits bearing won't last long compared to others....
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
Old 07-13-2007, 08:34 PM   #2743
Someone gave you some bad info. Mine has lasted for months. I just change it periodically. However, you do have to have your clutch set up correctly and do the preventive maintenance (cleaning and greasing) to keep it working properly.
neltime64 is offline   Reply With Quote
Old 07-14-2007, 03:55 AM   #2744
johnhsp's Avatar
Trader Rating: 18 (95%+)
Send a message via MSN to johnhsp Send a message via Yahoo to johnhsp Send a message via Skype™ to johnhsp
Here is my friend 720-07,body is copy gansei,thank gensei haha
Serpent 720-img_23791.jpg   Serpent 720-img_23801.jpg   Serpent 720-img_23811.jpg   Serpent 720-img_23831.jpg   Serpent 720-img_23841.jpg
johnhsp is offline   Reply With Quote
Old 07-15-2007, 09:09 PM   #2745
rcabj's Avatar
Default debut race
hi guys, just giving a preliminary review on my 1st race with the 720
with only 2 tanks of runtime wit d 720 in a different tracki went to this club race in another district wihout proper preparation and all those things u usually do b4 goin to races, .( coz it was a last minute decisionwhat the heck..just as long i got to raceeven didn't have time to put in my front Uni.) so making this story short , i qualified 5th overallduring the final i finish 9thtwice my glowplug blew on me...
- finals 1st 10 minutes with not a perfect setup it was sensational driving... i was running new tyres rear and 63mm tyres front....with 7.5mm rear ride height and 6mm front.
>>one more thing the track was using black pipes as the curbs...with few minor hits here and there, the car is still in one piece...the dogbone was also intact.
so for the next race in a few weeks, and with better preparation hopefully i can improved a lot.
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
