Old 06-14-2007, 04:24 AM   #2566
Gael L's Avatar
Originally Posted by Team Kamikaze View Post
It's just part of the pit strategy
LOL...I guess I'll call you on that.
Gael L is offline   Reply With Quote
Old 06-14-2007, 06:07 AM   #2567
dj apolaro's Avatar
Originally Posted by Killa G View Post
DJ what tires did you run in the main? Tire wear was pretty good but I guess you went a little harder since you didn't need a tire change
Gael
I ran hard tires and reserved them in the race. Started with 61.5 in the rear. pushed for first 15 minutes and then reserved for the end.
DJ
dj apolaro is offline   Reply With Quote
Old 06-14-2007, 06:08 AM   #2568
dj apolaro's Avatar
Originally Posted by Racer Z View Post
Great job DJ at 301!! Where you running the MF12?
Melvin
Yes.......
Old 06-14-2007, 06:28 AM   #2569
dj apolaro's Avatar
Default 301 race set-up
Race set-up for 301 Raceway in Maryland
front
lock
purple springs
35wt oil 1 hole piston layed down
sway bar flat
-1.5 front toe
0 droop
roll center middle position
3mm caster in front of arms
tires 40/42 harder on out side 58mm
ride height 5.25
1.75 camber
rear
diff with 60,000 in quals and 30,000 in main
yellow springs
35wt oil 2 hole piston 2nd hole from bottom
2.3 sway bar end of bar
2.5 toe in
5 droop
highest roll center position #4
camber link long and most angle
tires 42/45 harder on out side 59.5mm
ride height 6.5
camber 3/3.75
body 3.1 stratus with wing in the middle position
mega MF gearing 17/22 61/55
30% Maxys Fuel
Jaco tires
For the main I ran one more step harder on the tires.
DJ Apolaro
Old 06-14-2007, 07:01 AM   #2570
Dreddlox's Avatar
How much was left on your tires after the main?
Dreddlox is offline   Reply With Quote
Old 06-14-2007, 10:36 AM   #2571
dj apolaro's Avatar
I did not measure. Most likely about 5 more minutes. Not much though.......
Old 06-14-2007, 10:52 AM   #2572
rmdhawaii's Avatar
DJ ~ Was this your first time running the MF? How does the MF compare to the ZX?
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 06-14-2007, 11:21 AM   #2573
dj apolaro's Avatar
This was my second time. I ran it also at the region 4 race. The MF is less aggressive on the bottom. The ZX12 has more bottom and rips out of the corners. The MF is easier to drive and the power band is more linear. They are both good motors and depending on the track can have an advantage.
DJ Apolaro
Old 06-14-2007, 12:36 PM   #2574
Dj awesome performance. Congrats on your victory!!
Here is the link of his race report on serpent.com
http://www.serpent.com/news/12273/Ap...ssic-race.html
Paolo M is offline   Reply With Quote
Old 06-14-2007, 01:00 PM   #2575
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
DJ Apolaro
Hi DJ...i just read your report online...and noticed you had the same problem with various motors.......was the problem the gas tank?(the oring set up that some people are having problems with),.that would effect all the motors you ran?....
thanks
harry
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 06-14-2007, 01:03 PM   #2576
Team Kamikaze's Avatar
thanks
harry
I don't think there is anything to do with the gas tank, he mentioned that it run well after figuring out the shimming of the engine.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 06-14-2007, 01:06 PM   #2577
rmdhawaii's Avatar
DJ Apolaro
Great feedback. Thanks
Old 06-14-2007, 01:09 PM   #2578
Gael L's Avatar
thanks
harry
Many people were having run time issues this weekend due to the fact that it was a large flowing track. This may have been the case with DJ as well.
Gael
Old 06-14-2007, 04:43 PM   #2579
dj apolaro's Avatar
No tank issue. I was a coincidence that the shimming was wrong on both motors. Once that was fixed I was good.
DJ Apolaro
Old 06-14-2007, 04:44 PM   #2580
dj apolaro's Avatar
Gael
I made run time, no problem. I was able to run 5:35........
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
