Old 06-03-2007, 07:12 PM   #2536
CraigM's Avatar
Trader Rating: 34 (100%+)
Hi Serpent lovers, I'm thinking of picking up a 720 07, any words of advice? Most guys out here run mugens or kyoshos but I like to be different and from what i read the 720 is just as fast
Anyone know where I can get one cheap? needs to ship internationally, so far the best price I've found is RCmushroom for US$430 which seems pretty good
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 06-04-2007, 01:04 AM   #2537
thamjk's Avatar
Originally Posted by RevMaxx View Post
i would like to use lightened steel pinion gear for the 1st gear (17T). is there any? who makes them and where can i order this part?
i understand aluminum is lighter and better for acceleration but i believe its easy to lose track of the pinion wear that eventually will strip the spur (which is what happened to me). lightened steel should be harder and should relieve me of this problem
I am not sure if serpent has come out steel 17T pinion.
But 16T steel , ,,,yes.
thamjk is offline   Reply With Quote
Old 06-04-2007, 01:07 AM   #2538
Sow&Steady's Avatar
You mean faster ...
Although I'm no RCmushroom fan, that's a good price.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 06-04-2007, 02:18 AM   #2539
CraigM's Avatar
yeah service isn't their strong suit but EMS postage to Australia is cheap and ultra fast, plus they have Helios with Spektrum kit at a sweet price (US$345) so I might grab them together for a complete upgrade & save on postage
then sell a kidney
Old 06-04-2007, 08:40 AM   #2540
kyoshosan's Avatar
Send a message via ICQ to kyoshosan Send a message via MSN to kyoshosan
Hi Guys,
Im having an issue with the front differential on my 720. It keeps opening loose during the race and letting all the oil come out. I have changed the diff case, but the problem re-occurred last race. I use 50000WT on the front diff.
Any ideas ? Thanks in advance.
kyoshosan is offline   Reply With Quote
Old 06-04-2007, 09:21 AM   #2541
Derby Bros Racing's Avatar
Originally Posted by kyoshosan View Post
Hi Guys,
This might happen if you have the diff overfilled. When you rebuild the diff, try less oil. Filling it up until the oil touches the shaft is enough.
Derby Bros Racing is offline   Reply With Quote
Old 06-04-2007, 02:04 PM   #2542
Sow&Steady's Avatar
By "opening loose" you mean the screws undo themselves?
Don't overtighten when building it. The o-ring does the sealing, not the compression of the two halves of the diff casing.
Old 06-09-2007, 10:07 AM   #2543
Simon M's Avatar
Anyone got any tips on transponder mounting
Serpent 960
Serpent 720
Serpent S400
Serpent S120
Tamiya M03-R
www.serpentradiocontrolcars.com.au
www.smaracing.org
Simon M is offline   Reply With Quote
Old 06-09-2007, 10:30 AM   #2544
theres a notch at the back of the front bumper and two holes on the plate just behind the notch .the holes line up with the holes on the transponder ...that is where I mounted mine
fasteddie d is offline   Reply With Quote
Old 06-10-2007, 06:40 PM   #2545
Morgan Johns's Avatar
Default 720 Fuel Tank Air Leaks
Hello All,
Well I have been racing the 720 since the day it was released, and from day one I have had the issue with the tank loosing air pressure during a run and eventually leaning out my motor after about 2-3mins.
Again today in the Main it happened again after being fine all day, after taking apart the motor and everything else I did an air pressur test on the tank and as it turns out about 80% of the air was coming right out of the Cap, putting alittle pressure on the cap and voilla came out of the right exit.
I have probably bought about 9-10 different tanks and lids etc, I still havent gotten the rubber o-ring lid, has anyone experimented with this lid? I have heard mixed reviews, as some say the rubber o-ring expands when it gets saturated in fuel and makes it "harder" to close shut requiring a manual push down. I am even at the point where I am thinking of using an elastic band to keep the lid more secure.
All tips, hints and what you've done are more then welcome. Is there any aftermarket tanks anyone knows of?
Morgan Johns is offline   Reply With Quote
Old 06-10-2007, 06:43 PM   #2546
This is correct this is where my transponder is, however according to IFMAR and others its illegal to have the transponder infront of the front axle, for what ever reason this is, I have no clue, kinda stupid but for racing in IFMAR you'll have to double side tape it on the top deck, or if your using the new mini spektrum reciever you can "stuff" it in the reciever protecter/holder.
Old 06-10-2007, 08:53 PM   #2547
X1 Hybrid T1's Avatar
Default Tank
I tried the "O" ring lid and it didn't work for me. With the car on the bench, if I opened the carb, the engine picked up and with the build of pressure I could see the lid pop! With the "o" ring, the lid would not re-seal, and I had no tank pressure. I think the exhaust system generates more pres than is required in the tank line. I did make a line flow restrictor, but I went back to the regular lid and never used it. I might try it again, but for now I'm staying with the reg lid.
Dave
We don't stop playing because we grow old;
We grow old because we stop playing!
Dave Steen ROAR #5692
Serpent 720,710,9020, Xray T1-05
Jammin X1-CR,CRT,CRT.5,Asc T4,Losi XXX4
X1 Hybrid T1 is offline   Reply With Quote
Old 06-10-2007, 11:11 PM   #2548
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
CONGRATULATION TO TEAM SERPENT likewise to DJ for winning the 1/10 sedan at the Capitol Classic @ 301 raceway and Paolo for the 2nd place finish at the 1/8
buboy28 is offline   Reply With Quote
Old 06-11-2007, 04:28 AM   #2549
Sow&Steady's Avatar
Yes, very well done to Team Serpent there, DJ and Paolo on the top two podium.
Same here yesterday at Round 4 of the BRCA Nationals, Mark Green taking the win with the S720.
Old 06-11-2007, 06:47 AM   #2550
typer's Avatar
Just got my 720 '07 last week. any words of advice regarding the kit? Thanks
typer is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
