Serpent 720
Old 05-22-2007, 06:05 AM
  #2446
Originally Posted by Acid
Hi
I have the same problem with the clutch bearing. Didn't think of the bearing lube
But, you are right, that is the only lube I use and i have the problems you describe. I will change to another lube and see if it makes a difference.
Acid
WHOW.... That's the second case.... I think is the oil, because I'm the only one using it on my local track and I was the only one with this problem. A friend of mine said that some oil gets oxidate with light, and on those cases they can cause rusty. I think that is the case. I will start to use a cheap mineral oil, since mineral oils does not get oxidate.
E clean the car every week and does not use any liquids (no benzine or petrol oil). It must be the oil. lets wait to see if anybody else had the same problem.
regards
Eduardo
eduardo_garcia is offline
Old 05-22-2007, 09:20 AM
  #2447
Sow&Steady's Avatar
I also had problems when I got my kit - rear lower arms etc... and all I can say is, Serpent is a company thats stands by their customers - definitely - replacement parts in a flash
Just go through the thread and see the issues that some guys had and look at teh replies that Serpent posted... very few companies out there that provide such good service...
Hope this helps
Acid
Yeap, agreed.
And to cap off Harry's post, I was at the European Championships last year and wasn't even aware of the rear arm problems when Michael Salven was walking up and down the pits handing out bags of goodies to all 720 drivers. In it? A pair of new lower rear arms, a pair of new rear camber links with the end lugs, a set of stickers and a Serpent neck strap for your racer/mechanic
participant badge.
Sow&Steady is offline
Old 05-22-2007, 10:20 AM
  #2448
M7H
M7H's Avatar
Stt, Jamal...
We don't want everybody all over the world run Serpent cars!...
M7H is offline
Old 05-22-2007, 11:03 AM
  #2449
Sow&Steady's Avatar
Originally Posted by M7H
Stt, Jamal...
Who's Jamal?
Old 05-22-2007, 11:15 AM
  #2450
Originally Posted by Sow&Steady
Yeap, agreed.
participant badge.
At the EC-B in belgium there where even more parts in the bag!
They nearly gave me one
_cyclops_ is offline
Old 05-22-2007, 01:10 PM
  #2451
Sow&Steady's Avatar
Yeah and where's the promised video tape cyclops?
Old 05-22-2007, 04:29 PM
  #2452
does anyone know where i can get the mf12 engine
bosfan is offline
Old 05-22-2007, 04:32 PM
  #2453
Derby Bros Racing's Avatar
http://www.kamikazercracing.com/prod...hp?prod=221003
Derby Bros Racing is offline
Old 05-22-2007, 04:38 PM
  #2454
Originally Posted by Jo Gutierrez
thanks anywhere else?
bosfan is offline
Old 05-22-2007, 07:29 PM
  #2455
Dreddlox's Avatar
http://gasrccar.com/eshop/index.php?cPath=179_185
Dreddlox is offline
Old 05-23-2007, 01:46 AM
  #2456
Got the 3rd one way today. As I was assembling it I could not get the e clip that holds the 1st gear/one way bearing on. I pulled the shaft out and layed it side by side next to the stock shaft and found that the pin hole for the 2 speed adapter is closer to the end by about 1 mm, the shaft itself is shorter by about 2 mm.
Anybody has this problem also??
RoyU is offline
Old 05-23-2007, 02:04 AM
  #2457
Sow&Steady's Avatar
Nope, mine fit nicely.
Is the shaft black? Black is the right one.
Old 05-23-2007, 02:08 AM
  #2458
Yes the shaft is black, its the one that came with the 3rd one way set.
Maybe I'll grind a flat spot one the stock shaft
RoyU is offline
Old 05-23-2007, 02:44 AM
  #2459
Sow&Steady's Avatar
I can't remember the relative distance and differences but before you grind down, try fitting it again. Don't forget that the pulley adapter is different to stock so the spot where the allen crew goes is different too.
Are you sure you placed the black beveled spacer in the right place?
Old 05-23-2007, 05:21 AM
  #2460
it
it's Avatar
Default TIRE WEAR::
I am just wondering...
I usually True my Tires to 62 mm. Is 62 mm still thick or just enough. After a 5 min heat. My rear tires goes down to 60 mm. Am I using a soft compund tires or just my suspension is too stiff?
it is offline
