Old 05-17-2007, 05:57 AM   #2431
Sow&Steady's Avatar
Originally Posted by razzor
Note Acid that we are limited to a max of 10mm overhang.
best medium is mounting wing inline with bumper.
Razzor is correct, if you race to IFMAR/EFRA rules, or even local rules based on the these governing bodies, there is a limit for the over-hang as well as the height of the spoiler (has to be level or below the roofline).
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 05-17-2007, 06:08 AM   #2432
Default Missing '07 parts....
Already emailed the hobby shop and have an answer from serpent Europe.
They send the missing parts for my home place
Is it possible to identify the hardened plastic material and the new ruber o-ring in the fuel tank??? My fuel tank has a Black rubber o-ring and i think it is the '07 Version... I think the rest of the kit parts are the '07 and they arleady are aware of the parts missing.
SchuM is offline   Reply With Quote
Old 05-17-2007, 05:10 PM   #2433
razzor's Avatar
Originally Posted by Acid
Hi Guys
Forgive the stupidity of the question but I have to ask
When the rear spoiler is mounted further away from the front of the car (as far back as possible) = the most amount of rear downforce? When the rear spoiler is mounted closer to the front of the car = least amount of rear down force?
The above is true for long sweeping corners. Does the above hold for quick tight corners (90 and 180 degree) type corners?
Acid
Some interesting info
http://webzoom.freewebs.com/izzyinsa...ngBodyTips.pdf
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 05-18-2007, 01:40 AM   #2434
Hi razzor and Sow&Steedy
Thanks for the replies. Yes, you right, there is only a 10mm overhang allowed. Will try it out and see if it makes a difference.
Acid
Acid is offline   Reply With Quote
Old 05-18-2007, 01:44 AM   #2435
Hey razzor
Thanks for the info, really good to have.
Lets see if works for the next Nat race
Acid
Old 05-19-2007, 08:57 PM   #2436
THeGame's Avatar
Send a message via AIM to THeGame
Ran my 720 for the first time at 301 in Maryland today and all I can say is WOW..
Team Gravity Rc - G's R/C Raceway and Hobbies - Waldorf RC - TheTrack
THeGame is offline   Reply With Quote
Old 05-21-2007, 06:01 AM   #2437
Hi guys:
I have been using the serpent bearing oil for almost a year and I notice that on every place I drop the oil the part is rusty. I used it alot on the centax internal bearings and the engine shaft became so rusty that the bearing does not come apart (it is glued on the shaft). For the record, I only use a pincel and the serpent puffy for cleaning (nothing else). Is it caused by the oil?. I noticed that the oil became a little dark, and my friend said it is because the sun exposure on the track (it is really hot down here)
regards
Eduardo
eduardo_garcia is offline   Reply With Quote
Old 05-21-2007, 10:31 AM   #2438
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
How is the warranty support from serpent on these cars. Give me a run down , lets say from the box I have a bad part or was using the car and something was acting abnormal.
What kinda hoops do you have to go through?
Artificial-I is offline   Reply With Quote
Old 05-21-2007, 10:58 AM   #2439
Derby Bros Racing's Avatar
There were a number of people who had issues with the rear lower arms with the first batch of kits and I was one of those people. Informed Serpent USA and the free replacement showed up within four days. A fellow local racer bought a kit about a month ago. He must have gotten one of the first batch of kits (maybe an old stock from the hobby shop). Anyways, rear arm issues the first time he ran it. He also stripped a couple of the shock retaining plastics while he was building the kit. He called Serpent USA and they sent him free replacements package.
Derby Bros Racing is offline   Reply With Quote
Old 05-21-2007, 11:22 AM   #2440
Moderator
So pretty much you call , they believe and they send. This is about how hpi is. Sad mugen doesnt play the same.
Old 05-21-2007, 11:23 AM   #2441
rcpanama's Avatar
I had the same with the rear arms and retaining plastics from the shocks send an E-mail to Serpent-USA and a week later I had the replacement.
I bought the two kits from a Miami Dealer but I live in Panama and I was taken care of by Serpent USA.
RCPANAMA
Serpent 720 Novarossi Murnam 12 + 3CT Full Ceramic & 2630 pipe. 733 Novarossi Murnam 12 + 3SCT full ceramic & 2660 pipe , Nomadio Sensor, Xceed Lipo, Xceed Tires Japan Foam
rcpanama is offline   Reply With Quote
Old 05-21-2007, 06:07 PM   #2442
I too had a problem with the rear arms when the kit first came out. I emailed Doug at Serpent USA and was shipped a couple replacement parts days later. Kudos on responding to customer's needs.
James "Nel" Nelson
SpeedWorld Raceway & Hobbies | DesotoRacing.com | R1 Wurks
neltime64 is offline   Reply With Quote
Old 05-22-2007, 05:03 AM   #2443
Originally Posted by eduardo_garcia
Hi guys:
regards
Eduardo
Hi
I have the same problem with the clutch bearing. Didn't think of the bearing lube
But, you are right, that is the only lube I use and i have the problems you describe. I will change to another lube and see if it makes a difference.
Acid
Old 05-22-2007, 05:05 AM   #2444
I also had problems when I got my kit - rear lower arms etc... and all I can say is, Serpent is a company thats stands by their customers - definitely - replacement parts in a flash
Just go through the thread and see the issues that some guys had and look at teh replies that Serpent posted... very few companies out there that provide such good service...
Hope this helps
Acid
Old 05-22-2007, 05:29 AM   #2445
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
Serpent does not make an army of products...Customer service is paramount to them....and it shows in everything they do.......Do yourself a favor...get rid of that (WE NEED THE ID,reciept from an authorized dealer,notarised,serial numbered,not ordered from overseas,USA kits only...and thats for a 99 cent part)....MUGEN....and buy the serpent 720..........
and I'll tell you something else......you will never hear from serpent that they are busy making other kits,and THATS why there are no parts or kits for something you need......And thats the problem with alot of other companys these days(esp the new flavor of the month car....)
now...does that cover it OR WHAT!!!!!!!!!!!!!!!!!!
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
