Serpent 720
#2371
Originally Posted by Paolo M
Harry: you are rigth. We are oignto have 3 chassis for the 720. The std (silver and black, basically the same, just looks, SPP (front big hole and different design to allow more flex), SPP LCG to allow even more flex
Sam: This is the factory version of the few samples Serpent USA made in February for the Wnats. The SPP version is going to be the only one commercially available.
As Andrew said, this chassis, togheter with other new products, are going to be available to ship to dealers from next Tuesday. Check www.serpent-usa.com and www.serpent.com for the latest news
Rainer: The 720 info is ready. Expect e-mail on Monday
More goodies on the way: New products are coming out in the next few weeks: brass batterie trays for 960 and 720, front brass plate for 720 (fits SPP and SPP LGC), rulon clutch shoes (red ones for both cars), Front and rear softer blades for the sway bars, lithium batteries for both cars (fit std and brass batt trays) and much more!!!!
#2372
I'm having problems with bleeding and getting the proper rebound of the RCC shocks. Stripped 2 of the bottom inserts from loosening and tightening.
Its probably been posted in here, but what is correct way of "doing" the shocks, how much rebound, bleeding , etc.?
#2373
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
the Spp LCG is not going to be available?...
#2374
#2375
I meant that only SPP versions (both SPP and SPP LCG) are going to be available. The SUSA version is not going into the market
Sorry for not being more precise
Paolo
#2376
Fast,
Paolo
Paolo
#2377
Paolo- quick question for you on set up sheets, it looks like on most setup sheets, like the sheet for winternats 2007, that you have just one "dot" filled in for the shock pistons, does this mean you used one hole pistons or three hole pistons, one hole seems stiff, but just want clarification on this.... Thanks by the way on an awsome car, I am really happy so far with my new 720, ran it last weekend at the KC HOA, unfortunately we got rained out Sunday....
#2378
#2380
Originally Posted by SMcpot
Forgive my ignorance, but what's the advantage to having brass battery trays?
#2381
Thanks DJ, that's what I thought, just wanted to be sure...
#2382
FastH: No problem
Ffejdat: Dj already answer. It; means 3 holes opens. What's the KC HOA?
DJ: ready 4 301?
SMcpot and Sam: Kamikaze already answer thanks Sam. If you use the new SPP LCG, you are going to be under the minimum by a lot, so you can use the heavy battery tray.
I forgot to mention, also coming LCG one piece engine mount (i believe 2 to 3 mm lower) and smaller flywheel (31mm) So even lower CG having the engine lower, better performance
DJ: ready 4 301?
#2383
FastH: No problem
DJ: ready 4 301?
DJ: ready 4 301?
#2384
kansas city, Heart of America series.
#2385
Location: Costa Del Sol, Marbella, Spain www.bradir.net
lipo
Originally Posted by Sow&Steady
Add to that the upcoming Serpent low profile LiPo and you can lower the tank by about 3mm.
i thinki have a split second clip of that new lipo rx batt julius tested in his visit..the green light looks cool
http://one.revver.com/watch/231487
