Old 05-07-2007, 07:08 AM   #2341
Originally Posted by fatboy
I got a big problem with the traction roll whenever I race in a tight track.
Just wonder how would it be solved as i had tried too many ways in the setting.
Please advise.
Hi:
Can you explain what is the "traction roll"?
regards
Eduardo
eduardo_garcia is offline   Reply With Quote
Old 05-07-2007, 07:19 AM   #2342
Hi guys;
Yesterday I was setting up my car to use smaller tires (from 59mm to 55mm) I was trying to setup up the car to have 8 mm of ride height. However, the rear shock aren't long enough to have the necessary drop. (I couldn't have chassi upward travel). Do I need to buy long shock rods?
regards
Eduardo
Old 05-07-2007, 07:33 AM   #2343
rpoage's Avatar
Originally Posted by eduardo_garcia
Hi:
regards
Eduardo
When the grip level on the track increases to the point where it causes an abrupt weight transfer to one wheel when turning. A more precise explanation would be a imbalance in slip angles. Example the rear tires of the car will begin to release slide out in a right hand corner and the weight will transfer to the left front and cause it to "dig in" and flip the car.
Ashford Hobby
Real time inventory for the things you need.
rpoage is offline   Reply With Quote
Old 05-07-2007, 07:55 AM   #2344
Julius's Avatar
Hi guys;
regards
Eduardo
Although I'm curious why you'd want to run small ires with such a large ride height, I'd suggest using longer ball ends. You could try using the ball ends from the steering rods. It would save a lot of work installing longer rods.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 05-07-2007, 08:34 AM   #2345
Hi Julius.... Thanks for the answer...
The reason is that my local track is very bumpy and it is not in the "same level". You probaly know the track, it is the 2004 world championship track. I found out I can't handle my car well with a hide height smaller than 6mm ( the chassi hits the ground on the last turn) . So, the ideia is to keep the car above 6mm until the tire reaches 55mm. I'm using those small tires for pratice purpose only, not race.
Is anything wrong on this setup?
best regards
Eduardo
Old 05-07-2007, 08:59 AM   #2346
Julius's Avatar
best regards
Eduardo
No nothing wrong just curious
Did you ever try heavier damping (thicker oil or less holes) to make the bumps better?
Old 05-07-2007, 10:03 AM   #2347
Default Centax 3 Clutch
Hi Guys
I recently came across some information regarding the fly weights (3 black shoes at bottom of clutch) for the Centax 3 clutch.
By drilling holes in them and using the small set screws you will be able to weight the fly weights.
I have a question regarding this:
What is the benefit of using weighted fly weights? And when will you use it - is it track dependant?
Regards
Acid
Acid is offline   Reply With Quote
Old 05-07-2007, 10:43 AM   #2348
Oh yes.. I tried... To be very honest with you, I had a very hard time to setup the 720 for that particular track. To get a more predictable car, made the following modifications on the standard setup:
1- shocks with 2 holes (35w)
2- solid front axe (to avoid the traction rolling) I still need to test the front diff with 100k
3- blue springs on front, red on the back
4- 2.3mm rear roll bar
5- adjustable arkerman with the inner insert (long position)
6- caster with 1mm on the front
7- the rest of the itens on the standard setup
With this setup, I have a very easy to drive car, but with a little understeer on the corner entry. The front tire wear incrased substantialy, but the car is very predictable and fast enough for me
Old 05-07-2007, 10:54 AM   #2349
Gael L's Avatar
When running the long front ackerman with the front way has anyone had a problem with the ball joints hitting the pulley on the one way?
Gael
Gael L is offline   Reply With Quote
Old 05-07-2007, 11:56 AM   #2350
Gael
No. I haven't.. I'm using the ajustable long arckerman, not sure if it is different. I'm also using the 18T front belt tensioner (with the 19T), so it may give me an extra clearence..
regards
Eduardo
Old 05-08-2007, 08:41 AM   #2351
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
Jari Taskilla TQ, HOA season opener with his 720.
Finals were decided by quals due to heavy rain. 3 720's in the top 5.
Team Tekin, Team Scream, Paint By Mike, Team Mölzer Mowery Racing, EA Motorsports, Speedmerchant, TQ Wire
MMR Direct Minneapolis World Class Indoor Race Facility.
On Road and Off Road racing year round.
www.molzermoweryracing.com
http://www.facebook.com/pages/MMR/160679913944205?__req=9
Check out You Tube mmrswracing. Every qualifier and every main uploaded at the end of every race day.
ammdrew is online now   Reply With Quote
Old 05-08-2007, 07:51 PM   #2352
ianhobbies's Avatar
Location: Costa Del Sol, Marbella, Spain www.bradir.net
Send a message via ICQ to ianhobbies
Default site
julius recent trip to manila posted on the serpent website
http://www.serpent.com/news/12244/In...in-Manila.html
WWW.BRADIR.NET - The Radio Control Motorsport Blog! / twitter @ianhobbies
ianhobbies is offline   Reply With Quote
Old 05-09-2007, 07:30 PM   #2353
impalabob64's Avatar
Send a message via AIM to impalabob64
Thumbs up 3rd ONEWAY IS A MUST
Tried it ,an also the overdrive, wow what a difference the car was a dream to drive an had brakes also running a front diff, hey guys if you dont hve these hopups make sure you get them. .
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 05-11-2007, 04:18 AM   #2354
Hi guys,
This is my first message on R/C Tech boards.
My quesstion is I am planning to buy a Serpent 720 07 edition for races. But first of all I want to know the advantages and disadvantages of Serpent 720 07 to compare with Mugen MTX4-R, Kyosho V-One RRR WC edition and XRAY NT1?
Thanks.
GTi-6 is offline   Reply With Quote
Old 05-11-2007, 05:08 AM   #2355
M7H
M7H's Avatar
Go for the 720, it's got the best manual....
As you are in the Serpent thread, everybody would recommend you to buy the 720...
It is hard to compare the cars, because all 4 of them are good cars, I would even ad a fifth....the Team Magic G4.....
I would go with the car, you can afford, and for which your LHS gives you support.....
Serpent
M7H is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
