Old 04-19-2007, 09:39 PM   #2311
Julius's Avatar
Originally Posted by rcpanama
Ok thanks for your answer, let see if I understood:
If I need to correct an Over Steer condition, can I solve it by installing the 18T front Pulley and the two side pulleys to be 22T with a 1.5mm difference between the front and rear tire will give me a 1.61% more rear drive if I go to 3mm tire difference this will give me a 3.93% more rear drive.
Will the use of the 18T pulley correct the Over drive condition by increasing the rear drive ?
RCPNAMA
First of all: When using the 18t front pulley you need to use the 21t on the front shaft and the 22t on the 2speed shaft. Putting 2 22t pulleys on will probablt not fit!
Using more rear drive will make the car looser out of the corners. Increased rear overdrive will make the rear tires want to constantly overtake the front.
So if your only problem is oversteer out of the corner you could try running more front overdrive. That way the front tires will pull more and stabilise the car.
Usually though it is best to have close to 1:1 drive. That will be best for tire wear and make on and off throttle handling more equal.
Consider this: using more front drive to cure on throttle oversteer will very likely creat off throttle oversteer, because when you lift off the front tires will want to slow more than the rear making the car dive more and thus oversteer into the corner. (this can be cured when using the middle one way option).
Using the 18t is beneficial to equalise tire wear, and will make the car more predictable. Use the side pulleys as mentioned above with a 3mm split.
Hope this clarifies your questions
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 04-20-2007, 12:58 AM   #2312
Default Rear Stabiliser Bar
Thank guys... appreciate the input.
Think I will definitely try out the 2.3mm bar.
Thanks again
Acid
Acid is offline   Reply With Quote
Old 04-20-2007, 12:59 AM   #2313
Originally Posted by _cyclops_
Acid, check out Ruud Schuitmakers car...
Cyclops
Where would I find pics of Ruud's car?
Acid
Old 04-20-2007, 02:18 AM   #2314
Send a message via ICQ to _cyclops_
Originally Posted by Acid
Cyclops
Acid
Wont' help you, but it is his car
Can't help you any furture, but i tought you where at the MACH often.. so you should be able to meet ruud frequently
_cyclops_ is offline   Reply With Quote
Old 04-20-2007, 05:54 AM   #2315
rcpanama's Avatar
Thanks Julius, this is what I was looking for so I could undestand the over drive definition
Serpent 720 Novarossi Murnam 12 + 3CT Full Ceramic & 2630 pipe. 733 Novarossi Murnam 12 + 3SCT full ceramic & 2660 pipe , Nomadio Sensor, Xceed Lipo, Xceed Tires Japan Foam
rcpanama is offline   Reply With Quote
Old 04-20-2007, 08:03 AM   #2316
oze
Hi guys,
I want to measure the temperature of my engine. To get the accurate temperature reading I need to know the emission rate of the cooling head. I got Mega ZX12 DSII engine. What is the emission rate of the cooling head.
Thanks,
oze
oze is offline   Reply With Quote
Old 04-20-2007, 08:19 PM   #2317
Dreddlox's Avatar
I just picked up my 720 yesterday and wanted to know what weight diff oil are you guys using? Should I go with something thicker in the front?
Dreddlox is offline   Reply With Quote
Old 04-20-2007, 09:30 PM   #2318
oze
I am using 80000 in the front and 30000 in the rear diff.
Old 04-21-2007, 01:13 AM   #2319
Insane rc's Avatar
hi i am new here but i use 80000 front and 20000 in the back, this works
on most tracks here in holland.
Serpent 966 -Novarossi engines
Insane rc is offline   Reply With Quote
Old 04-21-2007, 05:32 AM   #2320
Dreddlox's Avatar
Thanks.
Old 04-21-2007, 09:15 PM   #2321
GHETTOTEACHER's Avatar
Dreddlox, I would not go that heavy on the front diff for tracks around here. 10000 and lower will do. Most tracks in the tri state area have very sharp and quick turns. You want to make that front diff to slow and give you turning.
Herolin <---Traded my Airtronics for an Ipad and Laptop...
Soon to be GHETTOPRINCIPAL..
GHETTOTEACHER is offline   Reply With Quote
Old 04-25-2007, 01:24 AM   #2322
Hi,
can anyone please tell me the size of the screws that come with the optional 803175 bracket radio plate support? Is there a part number for them?
I ruined two of them and I can't find the replacement in any hardware store.
blackarrow is offline   Reply With Quote
Old 04-30-2007, 05:56 PM   #2323
rccobra705's Avatar
Default Serpent 710/720
Originally Posted by blackarrow
Hi,
Really, know one knows, because I have same problem. Please inform us the Serpent part # and/or the size.
Regards
rccobra705 is offline   Reply With Quote
Old 04-30-2007, 09:57 PM   #2324
oze
I do not know the answer on your question because I do not have this part. Blackarrow still has got two screws. Why do not you measure the size of those screws and let rccobra know. I am sure these are pretty common metric screws, probably M4 x 10, or so.
Old 04-30-2007, 10:30 PM   #2325
X1 Hybrid T1's Avatar
Default Size
It looks to me like 3.5x8mm flat head. Serpent #1277. I hope that works.
Dave
We don't stop playing because we grow old;
We grow old because we stop playing!
Dave Steen ROAR #5692
Serpent 720,710,9020, Xray T1-05
Jammin X1-CR,CRT,CRT.5,Asc T4,Losi XXX4
X1 Hybrid T1 is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
