Old 04-09-2007, 04:51 AM   #2266
Sow&Steady's Avatar
Originally Posted by thamjk
I bought the 16T steel pinion tought if this part will last longer then a aluminium pinion. If I put it in 710 or 720 i have to slant the engine a lot which you can see from the top view (plan view).
But if I use the 16T aluminium pinion. it looks ok. I guess maybe not many people use 16T therefore no one notice this problem.
If you take a close look of the steel and aluminium version, the 16T steel version has a smaller diameter... please take one and try ... then you will know what i mean...
thanks for your response..
Really ... you should not need to use the 16t for the 720. Like Julius said, the internal ratio was designed so that you don't need the 16t.
Now on the 710 its a different story.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 04-09-2007, 07:58 PM   #2267
thamjk's Avatar
yeah.. thanks
Its just a discussion to ask around see if anyone has different opinion.
appriciate that..
Serpent 710
Nova MAX
3PK
thamjk is offline   Reply With Quote
Old 04-10-2007, 12:46 AM   #2268
Derby Bros Racing's Avatar
yeah.. thanks
appriciate that..
The local track we have here is very small and I use the steel 16T on my 720 (OS motor). It's tricky to mesh but take your time and you will have it straight and working. I ended up having the second speed really tight when new to have the first (16T) meshed properly. Run a couple of tanks to "break-in" the gears. On a side note, I have been using the same 16T on my 720 (racing every week) since September last year.
Derby Bros Racing is offline   Reply With Quote
Old 04-10-2007, 03:05 AM   #2269
Default Overdrive
Hi Guys
I have a question about overdrive on the 720... not sure if you guys answered this on the post somewhere, if you did, please forgive the question...
On the 720, do you want more rear overdrive or front overdrive? Is your overdrive selection based on the track or is there a stock setting (band, e.g between 5% front and 5% rear is perfect) that you should strive for?
Acid
Acid is offline   Reply With Quote
Old 04-10-2007, 02:43 PM   #2270
Hi Guys, a simple question.... I use the 18T front pulley conversion so always run a 3mm tyre split front to back.In wet weather it is rubber tyres that seem to work the best but they are the same diameter front and back.Whats the easiest way to regain the correct overdrive ratio for use in wet weather? Cheers All
Woodchop is offline   Reply With Quote
Old 04-10-2007, 04:00 PM   #2271
roadrage's Avatar
Trader Rating: 14 (100%+)
put stock pulley set-up back on?
Austin Wolfe
Serpent America-Trinity/Revtech-www.ActivRC.com
roadrage is offline   Reply With Quote
Old 04-10-2007, 09:17 PM   #2272
thamjk's Avatar
Originally Posted by Acid
Hi Guys
Acid
I prefer to have the stock setting which is a slight front overdrive.
I don't prefer rear overdrive.
Too much front overdrive the handling on trottle is wired.
Serpent 710
Nova MAX
3PK
Old 04-11-2007, 02:11 AM   #2273
Thanks Thamjk...
I agree, when there is too much front OD, I find the front of the car "sticks" going into bends and the back gets slightly loose....
Thamjk, what is your stock setting - whats your front/back tyre split?
Acid
Old 04-11-2007, 03:46 AM   #2274
thamjk's Avatar
Thanks Thamjk...
Acid
If you use the 18t pulley (optional) it generate lesser front over drive, lesser then the stock 720.
I usually use stock with 1.5mm split.
Serpent 710
Nova MAX
3PK
Old 04-11-2007, 02:33 PM   #2275
Due to the fickle weather we have in my home country it can sometimes rain and dry very quickly. This is why i was wondering if there is a quick way to get an appropriate overdrive ratio-when using rubber tyres (which are the same size on the front and back of the car)!!! There would not be sufficent time to pull the front of the car apart to put the original pulley setup on!
Old 04-11-2007, 10:38 PM   #2276
wizby's Avatar
I have seen a spring chart somwhere. But cant find it again. It had the soft color on one end and hard color on the other end. I have no idea were I saw it. Anyone know what I mean? I searched all over serpent.com and didnt see it again. Even better would be a part number to buy the entire set of shock springs.
XRAY NT1 2014 NOVA KEEPON DX3R
MIKE PARKER PRESIDENT
NORTHERN INDIANA TEAM RACING ORG. MIDWEST SERIES TEAM DIRECTOR
wizby is offline   Reply With Quote
Old 04-12-2007, 03:47 AM   #2277
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
if you buy the kit Serpent has the manual plus some supplementary booklets for set-ups and parts and i think you can find the springs ( from softest to hardest) in the supplementary booklets
buboy28 is offline   Reply With Quote
Old 04-12-2007, 04:21 AM   #2278
rmdhawaii's Avatar
It's on page 21 of the setup booklet:
http://www.serpent.com/file.php?FileID=4719
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 04-12-2007, 08:10 AM   #2279
Julius's Avatar
Originally Posted by trickd122
Julius
Just a few questions
How do you go about choosing your dampening package for a particular track?
do you choose the springs first, oil wt then pistons?
The RCC shocks, how much rebound do you build them with?
Finally what is the objective to have the hardest spring/oil wt and soft tires
or hardest tires and softest suspension?
Hi,
To start with the last question. The objective is to have the lowest laptime with the easiest handling.... Seriously some tracks will require stiff combo's (think about Ft Meyers with the fast chicanes where you need response) and sometimes you have more flowing tracks that allow softer combos for more control.
The rebound of the rcc shocks should be about half to 2/3s travel when released after full compression. Easiest way to achieve that consistently is using the rcc shock tool from serpent during assembly. It makes sure the piston is in the optimum position during bleeding and this gives very good rebound results.
Your first question is the most difficult....
To be honest I do not chage damping a whole lot. I mostly run 35wt all round with either 2 or 3 hole pistons. One thing to have in the back of your mind is that in bumpy tracks harder damping will often give better results than soft damping.
Spring hardness can change a lot in response of the car. Harder will give quicker response but less grip. Harder is often better in fast corners. Softer for hairpin type corners.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 04-12-2007, 08:31 AM   #2280
Originally Posted by Julius
Hi,
How do you use the shock tool to achieve this?
James "Nel" Nelson
SpeedWorld Raceway & Hobbies | DesotoRacing.com | R1 Wurks
neltime64 is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
