Serpent 720
Old 03-30-2007, 06:39 PM
  #2236
Team Kamikaze's Avatar
Originally Posted by captian
ya i was looking for one too can you post where to get when there out
The Masmo MF12 has been out, and who ever carries Serpent should have it in stock.
Team Kamikaze is offline
Old 03-30-2007, 06:57 PM
  #2237
captian's Avatar
sorry i was talking about the pit towel . but thanks away
captian is offline
Old 04-01-2007, 07:55 PM
  #2238
RevMaxx's Avatar
Originally Posted by redsand
Yes, it is indeed a Serpent electric sedan. Here's the link
will the serpent electric sedan have common parts with the 720? maybe like shocks, rear/front arms etc.
if there will be quite a number, might be a good time to try EP
RevMaxx is offline
Old 04-01-2007, 10:57 PM
  #2239
The shocks probably, since they are used on all their cars...
_cyclops_ is offline
Old 04-02-2007, 07:00 AM
  #2240
kyoshosan's Avatar
What is the difference between the Serpent Clutch shoe Yellow and the XP ?
Thanks in advance.
Alexandre Kyoshosan
www.copainferno.com.br
kyoshosan is offline
Old 04-02-2007, 12:01 PM
  #2241
captian's Avatar
Thanks in advance.
Alexandre Kyoshosan
the xp is softer and gives you more bit but does not last as long . yellow is standerd and it is long wearing and does not have the bit depending on your clutch set up
captian is offline
Old 04-02-2007, 12:13 PM
  #2242
the arms from the 720 are different then the arms on the electric car
Jeff Cuffs is offline
Old 04-02-2007, 09:07 PM
  #2243
rmdhawaii's Avatar
Mark Green wins Round 1 of 200mm UK Nats
http://www.redrc.net/2007/04/mark-gr...200mm-uk-nats/
720 wins again. ... and Kyle Branson picks up 4th. That kid is a really talented driver.
rmdhawaii is offline
Old 04-04-2007, 10:55 AM
  #2244
kyoshosan's Avatar
Cool
Serpent makes 2 different Optional Engine mouting blocks:
- Serpent 710/720 Engine Mono-Block Mount M12 For Mega-Picco
[SER-802553]
- Serpent 710/720 Engine Mono-block Mount M12 NR-Based
[SER-802552]
Does anyone know which one is the right one for O.S Engines and for the New RB Speedline Matrix ?
Thanks in advance.
Alexandre Kyoshosan
Old 04-04-2007, 10:59 AM
  #2245
[SER-802553]
[SER-802552]
Thanks in advance.
Alexandre Kyoshosan
SER802552 is the one for any other engine like the Nova Rossi/OS/Sirio etc... except PICCO based engine.
RB Speedline Matrix engine is the same as a Sirio engine.
Old 04-04-2007, 11:58 AM
  #2246
kyoshosan's Avatar
Smile
Team Kamikaze,
The Mega .12 MASMO Engine is Novarossi based, right ?
Thanks again.
Alexandre Kyoshosan
Old 04-04-2007, 12:34 PM
  #2247
Team Kamikaze,
Thanks again.
Alexandre Kyoshosan
Yes it is a Nova Rossi based engine Hand modified by Massimo Fantini, It has a CNC Machined piston and Ceramic bearings.
Old 04-04-2007, 03:58 PM
  #2248
Ffejdat's Avatar
As long as you are talking Monoblock mounts, what mounts do both the new GRP- Ninja motor, and the Orion Wasp CRF motor use, I am guessing Nova for GRP, and Picco for CRF, but can anyone confirm this?
Ffejdat is offline
Old 04-04-2007, 07:16 PM
  #2249
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
We use the MF mount for the picco and MF motors. The picco one is slightly smaller so the larger case of the MF will not drop in as easily
ammdrew is offline
Old 04-04-2007, 07:35 PM
  #2250
When is the MF mount released?
