Old 03-23-2007, 11:39 PM   #2206
nigelnuggets's Avatar
Send a message via AIM to nigelnuggets
Rainer! i just saw the 720 KB. looks great man!
Kamikaze Toys and Hobbies. www.kamikazetoysandhobbies.com / www.kamikazercracing.com
nigelnuggets is offline   Reply With Quote
Old 03-23-2007, 11:57 PM   #2207
suntok2's Avatar
Send a message via ICQ to suntok2 Send a message via AIM to suntok2 Send a message via Yahoo to suntok2
Can anyone please tell me what the difference between 720 vs 720 07'? Thanks
suntok2 is offline   Reply With Quote
Old 03-24-2007, 12:10 AM   #2208
rmdhawaii's Avatar
kyoshosan and suntok2 ~ Sorry guys, can't help you with the part numbers. I checked out the Serpent site, but I can't determine what you need to put together your own "upgrade kit".
Okay Team Serpent, we need your help!
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 03-24-2007, 12:12 AM   #2209
rmdhawaii's Avatar
Thanks Nigel.
Old 03-24-2007, 03:45 AM   #2210
Sow&Steady's Avatar
Suntok and kypshosan, from what I remember, the difference are the following :-
- just for looks, Serpent have anodised the chassis black.
- Servo Saver with adjustable Ackerman
- LeMans type bumper as an added extra
Everything else the same.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 03-24-2007, 04:44 AM   #2211
Send a message via ICQ to _cyclops_
-CVD's as standard.
- Nilon pivot nuts
_cyclops_ is offline   Reply With Quote
Old 03-24-2007, 08:42 AM   #2212
roadrage's Avatar
Trader Rating: 14 (100%+)
and the new hardend plastic
Austin Wolfe
Serpent America-Trinity/Revtech-www.ActivRC.com
roadrage is offline   Reply With Quote
Old 03-24-2007, 10:45 AM   #2213
rmdhawaii's Avatar
Here are the descriptions of the what's included in the '07 kit (KB), but the lists I've seen do not have any part numbers and I'm not going to take a stab and guessing what the correct part numbers are:
* Front CVD shafts
* Extra one way front shaft with lock set
* Nylon adjustable pivot ball nuts
* Upgraded fuel tank with o-ring sealed AFL lid
* Servo saver with adjustable Ackerman
* New hard plastic suspension parts
* New black anodized chassis plate
Old 03-24-2007, 11:28 AM   #2214
rpoage's Avatar
* Front CVD shafts SER 802350
* Extra one way front shaft SER 802245 ??
* Front shaft lock set SER 802252
* Nylon adjustable pivot ball nuts SER 803198
* Upgraded fuel tank with o-ring sealed AFL lid SER 803179
* Servo saver with adjustable Ackerman SER 803192
* New hard plastic suspension parts Running change ?
* New black anodized chassis plate ????
This is my best guess on this.
Ashford Hobby
Real time inventory for the things you need.
rpoage is offline   Reply With Quote
Old 03-24-2007, 09:47 PM   #2215
Neptune's Avatar
So who all uses the overdrive kit and can could sombody tell me the pros and cons. Also if you do use it, do you use it with the 3rd one-way.
Neptune is offline   Reply With Quote
Old 03-25-2007, 07:45 AM   #2216
Pyramid's Avatar
Sumarry explanation from the designer,
The 3rd oneway frees up the drive train, especially off throttle. It will also make the car rolls more (but you could use drag brake to adjust the roll).
The most advatage is on longer runs when the rear tires tend to get smaller, you have less problem with an unsettled rear end while turning into a corner. It`s not really a tool to get faster laptimes (on some tracks it will be) but more consistence and better fuel mileage for sure.
The 18t pulley will helps on tire wear issues between front and rear in longer runs. The advantage is, that the front tires wears harder than before. So the difference (in wear) front rear is more or less the same. It also helps against traction rolling. It's not a very big step, but you can feel the difference.
Pyramid is offline   Reply With Quote
Old 03-25-2007, 09:00 AM   #2217
wizby's Avatar
I have to think guys are still experimenting with the 3rd oneway and overdirve kit. There hasn't been alot of discussion on it yet. I just received both kits,haven't had good enough weather to test yet.
XRAY NT1 2014 NOVA KEEPON DX3R
MIKE PARKER PRESIDENT
NORTHERN INDIANA TEAM RACING ORG. MIDWEST SERIES TEAM DIRECTOR
wizby is offline   Reply With Quote
Old 03-25-2007, 08:29 PM   #2218
thamjk's Avatar
Does it come along with front CVD spring steel?
Serpent 710
Nova MAX
3PK
thamjk is offline   Reply With Quote
Old 03-26-2007, 02:36 AM   #2219
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
i do'nt think so but the new CVD's are thicker than the first released
buboy28 is offline   Reply With Quote
Old 03-26-2007, 09:24 AM   #2220
The Airtronics Championship has been completed at Revelation Raceway, it was the last race of the year for our track is closing. But we finished it with a bang! Walter was also using the new OFNA JL Racing .12. Amazing fast!
Pos Car Laps time name
1 1 148 40:10.80 JEFFREY LIN (Ofna GPX4/JLR Reddot.12)
2 2 146 40:02.96 WALTER DIAZ (Serpent 720/JLR Reddot .12)
3 9 146 40:13.18 CHRIS VELEZ (Mugen MTX4/Novarossi Plus 12-3CT)
4 8 145 40:08.92 DARIN ISHITANI (Mugen MTX4/Ninja .12)
5 0 145 40:11.26 PETER CHHU (Mugen MTX4/JLR Reddot .12)
6 7 143 40:14.19 MARCO ACOSTA (Mugen MTX4/JLR Reddot .12)
7 6 136 40:08.43 ROBBIE COLLINS (Mugen MTX4/Ninja .12)
8 3 106 35:31.83 MIKE STRACK (Mugen MTX4/Ninja .12)
9 5 104 30:17.67 ALEX NAVARRETE (Mugen MTX4/JLR Reddot .12)
10 4 70 21:55.98 PEPE VELEZ (Mugen MTX4/Novarossi Plus 12-3SCT)
Walter did an excellent job battling with Darin Ishitani for numerous laps back and forth and back and forth but prevailed with excellent pit strategy and consistent laps! Although Walter could've possibly finished on the same lap as Jefferey, but the car flamed out twice for some odd reason. The motor went rich and decided to flame out at the 4:40 mark. But with quick pitwork we were able to put him in the #2 spot. Great job Walter!
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
