Old 03-12-2007, 03:52 PM   #2101
Julius's Avatar
Easiest things to try.
A lower rear roll center (go to mid lower) and see if this is the right path.
Higher front roll center (mid)
or front diff a bit tighter
Or inner camber rise position
Any of these will creat a more stable rear.
The camber link will have a big effect on agility of the car, and you may lose too much in the hairpins.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 03-12-2007, 03:56 PM   #2102
rcpanama's Avatar
Thanks Julius
Serpent 720 Novarossi Murnam 12 + 3CT Full Ceramic & 2630 pipe. 733 Novarossi Murnam 12 + 3SCT full ceramic & 2660 pipe , Nomadio Sensor, Xceed Lipo, Xceed Tires Japan Foam
rcpanama is offline   Reply With Quote
Old 03-12-2007, 06:55 PM   #2103
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Julius, hope to race with you this coming Friday and do hope you enjoy your short stay in our country
buboy28 is offline   Reply With Quote
Old 03-12-2007, 08:30 PM   #2104
thamjk's Avatar
Default Serpent clutch
Hi
Is there a method you guys applied to find out whats the best clutch tuning for your car each time you change to different engine. I know different engine has different tuning.
Serpent 710
Nova MAX
3PK
thamjk is offline   Reply With Quote
Old 03-13-2007, 02:06 AM   #2105
Julius's Avatar
Me too. I hope I'll be awake enough to give you guys a tough time!
I'll try and give some tech seminar if people are interested. So think about possible subjects.
Old 03-13-2007, 07:19 AM   #2106
GHETTOTEACHER's Avatar
I have a question about getting the gearing and tire size right for proper handling. I was told to cut my front tires 1 mm smaller than the rear. Now, I do know that under normal race use, the rear will grind down; but what is the proper size to gearing for almost a 50/50 front/rear drive ratio ? My math is telling me that I should have a 1.5mm difference between front and rear tires.
I would appreciate any input to this matter.
BTW, This applies to non center one way equipped cars.
Herolin <---Traded my Airtronics for an Ipad and Laptop...
Soon to be GHETTOPRINCIPAL..
GHETTOTEACHER is offline   Reply With Quote
Old 03-13-2007, 10:07 AM   #2107
Derby Bros Racing's Avatar
Originally Posted by thamjk
Hi
The USA kit (I'm not sure about the others) came with a supplemental sheet that has the clutch gap info for all the major brands of motors currently available. It's a very good starting point and helps a lot especially if you are using different brands of motors.
Derby Bros Racing is offline   Reply With Quote
Old 03-13-2007, 11:23 AM   #2108
Has anyone ever run the Serpent truck body (#170027) and does anyone know of any store that stock these in U.S.?
We're thinking about starting a class with these at our track.
James "Nel" Nelson
SpeedWorld Raceway & Hobbies | DesotoRacing.com | R1 Wurks
neltime64 is offline   Reply With Quote
Old 03-13-2007, 06:15 PM   #2109
trickd122's Avatar
Hi
Very good question
TEAM MAGIC "making my competition disappear"
trickd122 is offline   Reply With Quote
Old 03-13-2007, 07:55 PM   #2110
RevMaxx's Avatar
Send a message via MSN to RevMaxx
buboy, will you be joining cebu invitational next month? if so, what kit will you be running with?
RevMaxx is offline   Reply With Quote
Old 03-13-2007, 08:17 PM   #2111
thamjk's Avatar
Originally Posted by trickd122
Very good question
I know it sound difficult so answer. very subjective.
Same goes to tuning and break-in engine, i have seen some very good article about this part.
I am sure serpent clutch do have the same thing. just that probably we need ask someone more experience to explain on that.
Serpent 710
Nova MAX
3PK
Old 03-13-2007, 08:35 PM   #2112
thamjk's Avatar
Originally Posted by madbeats
Well i would like your guy's to see my color's for my 720
this is the nice one.
Serpent 710
Nova MAX
3PK
Old 03-13-2007, 09:59 PM   #2113
buboy28's Avatar
I WILL BE RUNING MY 72O HOPE TO SEE YOU GUYS THERE AND PLEASE SAY HI TO DOKI( KEITH) FOR ME
Old 03-13-2007, 10:18 PM   #2114
RevMaxx's Avatar
awesome... good to know you'll be joining with the 720, at least for now there will be 2 - 720 presence in the event. i'm still a newbie on touring and will be my 1st race so looking forward for the experience and hope to learn good tips
doki-doki (keith) left for the US last month and i believe is now in florida, sadly he won't be able to join the event.... cool!!!
Old 03-13-2007, 11:13 PM   #2115
Hi
Here's the supplemental sheet I was talking about. It came with the USA kit I got last August 2006.
This is to be used with the hard clutch spring (also came with the USA kit). You may need the manual to follow the instructions on how to setup the end play, etc.
Hope this helps .
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
