Old 03-11-2007, 03:05 PM   #2086
impalabob64's Avatar
Send a message via AIM to impalabob64
Default CRF IN 720
NEPTUNE,BOBBY HERE IS MY CRF SETUP,GEARING 17/61,22/55 .I ALSO DRILL THE SERPENT FLY WEIGHTS AN THE ADD TWO GRUB SCREWS TO EACH FLY WEIGHT,THE CLUTCH SPRING SHOULD,BE TIGHTEN UNTIL YOU SEE A THREAD AN A HALF SHOWING,YELLOW SHOE,TIRES BETWEEN 59.5 FRT,61.5 REAR OR 57.5FRT 59.5 REAR DEPENDS ON TRACK THOUGH.
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 03-11-2007, 06:08 PM   #2087
B4
B4's Avatar
Originally Posted by Neptune
Does anyone run the Orion .12 CRF in their 720? How do you like it and did you have to change the gear ratios like most have with other cars?
Using the Murnan version in mine with the Orion clutch (2weights). This week i'll be trying the 16T pinion to see the difference.
B4 is offline   Reply With Quote
Old 03-11-2007, 10:58 PM   #2088
nigelnuggets's Avatar
Send a message via AIM to nigelnuggets
Originally Posted by B4
Thanks nigelnuggets,
That looks like it to me. It would be good if Serpent put this part number with the set.
Anytime man, always here to help!
Kamikaze Toys and Hobbies. www.kamikazetoysandhobbies.com / www.kamikazercracing.com
nigelnuggets is offline   Reply With Quote
Old 03-12-2007, 07:30 AM   #2089
For the record.... I tested the floating rear mount yesterday on my local track (2004 Brazil world's) on a sedan body. It gave a lot of downforce on the long and fast turn we have here. I was able to do the turn a lot faster due to this extra help. From my point of view, it does not make much diference on the slow turns, but it is very good on fast turns. My lap time falls 0.5 secs...
eduardo_garcia is offline   Reply With Quote
Old 03-12-2007, 07:52 AM   #2090
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
is it possible to convert the 720 rcc shocks to use the internal click to adjust dampening feature?....If not,is Serpent coming out with a conversion....I think that is a great feature,not sure why they got rid of it....
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 03-12-2007, 07:59 AM   #2091
Send a message via ICQ to _cyclops_
That's not needed anymore because you can just as easy (ok, not just as easy, but very easily) refill the shocks...
I actually think it can be possible to create the same system, but it will be very hard to do it yourself...
_cyclops_ is offline   Reply With Quote
Old 03-12-2007, 08:08 AM   #2092
Julius's Avatar
We did away with the system, because it proved too difficult for many to get 4 shock exactly the same. We are not considering implementing the system in the RCC shocks.
Shock travel would be severely limited when you would install the old adjustable pistons.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 03-12-2007, 08:19 AM   #2093
when will the '07 car be available?
Joe Chaplow is offline   Reply With Quote
Old 03-12-2007, 08:50 AM   #2094
fastharry™'s Avatar
thanks Julius.....let me ask you another question....does serpent still make the old shocks,with metal bodies,that have the 4 step pistons....and would they be the right length,travel, etc for 720?...
Old 03-12-2007, 11:10 AM   #2095
Xray still uses the same system, and i think the sizes are the same....
(some ppl might find this comment quite lame :P)
Old 03-12-2007, 11:39 AM   #2096
fastharry™'s Avatar
thats what i was thinking(and again,they would have to be the right size,length,etc)...but I'd rather stick with serpent if possible.....I loved those shocks on my Impulse....
Old 03-12-2007, 12:18 PM   #2097
We will got it in next week
Paolo
RCtarget, Capricorn, Novarossi, Maxima MX Fuel, Matrix, Xtreme Aero, Avid, Ko Propo, Veytrex Lab, Blast RC, PMR
Paolo M is offline   Reply With Quote
Old 03-12-2007, 12:59 PM   #2098
Paolo
thank you.
Old 03-12-2007, 02:10 PM   #2099
Julius's Avatar
Yes we still have them available. You'd need only the front shocks though. If I remember correctly the package was for two shocks, with enough plastic parts to make either two fronts or two rears. So you'd need two sets and two pairs of front alu housings.
I do believe the Xray shocks have a different lenght. (somewhere midway between Serpent front and rear).
Old 03-12-2007, 03:35 PM   #2100
rcpanama's Avatar
Default Advice on Set up change
Hi Julius, I tested the 3rd one way and new chassis on Sunday, the result was excellent, the 3rd one-way was unnoticed, it didn’t really affected my driving, braking was as normal as always, the benefit was that the difference between the front and rear tire was minimal, I started with a 1.5mm lower in the front than the rear, after 20 minutes of raising I had a 1.5 to 2mm difference between the rear and front, not any more the difference was lest than 1mm.
The new chassis in my track was better with the carbon plate install, I always had traction roll, not at all with the new chassis the combination of 3rd one way and new chassis was excellent I Think Serpent had a AAA with this options.
I have a technical question in regards to my Set Up, the set up I am showing is the normal set up I am using, our track (Parking lot) has a low to mid traction, with two fast turns and two hair pins, I am having some problem getting read of a excess Over steer in Conner Exit on Throttle:
What will be the area I should change most to correct it with out affecting to much the performance of the car. (This is most to happen went the traction of the track is low)
SET UP I HAVE
SPUR
59/56
Pinion
17/23
Front Axle
Ball Diff with Alu Collar
Rear Axle
Diff with 10,000
Front Shock
Three (3) holes 35 Red Spring
Rear Shocks
Two (2) holes 35 Red Spring
Front Anti Roll Bar
45°
Rear Anti Roll Bar
o.o mm
Front Tyres
40 Jaco Serpent 63.5mm
Rear Tures
40 Jaco Serpent 65mm
Engine
Novarossi Plus 12 3CT Murnan Headshim 0.4mm
Pipe
Novarossi 2630 six fins
Body
Stratus 3.1 (34 mm)
Front Roll Center
Top
Rear Roll Center
Mid Upper
Rear Camber Link Position
Bottom
Rear Camber Rise Position
Outer
Front Shocks Mounting
Second lowest
Rear Shock Mounting
Lowest
Front down Stop
0 mm
Rear down Stop
7.0 mm
Front Camber
2° Left & Right
Rear Camber
3° Left & Right
Front Toe out
1
Rear Toe in
2.5
Side Pulley 22t
Servo Saver
Long
RCPANAMA
Serpent 720 Novarossi Murnam 12 + 3CT Full Ceramic & 2630 pipe. 733 Novarossi Murnam 12 + 3SCT full ceramic & 2660 pipe , Nomadio Sensor, Xceed Lipo, Xceed Tires Japan Foam
rcpanama is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
