Old 02-28-2007, 05:54 AM   #1966
Julius's Avatar
Originally Posted by eduardo_garcia
Well... It is a oneway on de 24t pulley. It means that the oneway will engage on the on-throttle scenario. When you apply the brake, the oneway will desengage..Isn't it correct? I mean, with this optional we will only have brakes on the front wheels.....
Can anybody confirm it for me?
regards
Eduardo
The thing you are missing is that the brake disk is connected to the 24t pulley directly and not via the one way. That means that when you brake the rear wheels will always brake. And only when the fronts are turning faster than the rear (which would be the case when the rear starts to lock up) the fronts will brake too. This has the effect that you lose less steering under braking!
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 02-28-2007, 08:47 AM   #1967
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
hi julias....would it still be possible to overdrive the car using the one way brake pulley?
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 02-28-2007, 09:00 AM   #1968
asil's Avatar
Send a message via MSN to asil
Hey man, good question..
Asil
asil is offline   Reply With Quote
Old 02-28-2007, 09:13 AM   #1969
Yes, it would be my next question. When the front tires are smaller than the rears, the front will always turn faster then the rears. On this scenario, the oneway will be engaged even on off throtle. when the rear tire is smaller than the front, the oneway will always be disconected (the rear would turn faster then the front). May be this is the purpouse of this hop up, it may equalize the tire wear. Good discussion...
Thanks Julius for your support. That's why serpent rocks...
eduardo_garcia is offline   Reply With Quote
Old 02-28-2007, 12:33 PM   #1970
ALG
Originally Posted by Paolo M
Setup 720 Ft Myers
Hi Guys,
Attached you will find the setup i use at the race. It is pretty much the same we had posted at the race. We basically change the front springs.
Please don't hesitate in asking any question. I may take a little to answer but i will try my best
Happy Racing and Enjoy
Hi Paolo: did you made a tire change on the final? looking at your times I can see a looong pit stop or did you had a problem on the track.
Regards from Peru!!!
ALG is offline   Reply With Quote
Old 02-28-2007, 01:16 PM   #1971
rmdhawaii's Avatar
Does anyone know if Serpent is going to offer a 720 to 720 07 update/conversion kit?
Thanks!
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 02-28-2007, 01:58 PM   #1972
dj apolaro's Avatar
Thanks!
Not sure if they will offer a kit, but the items will be available to purchase. I also sent you an e-mail with the info you requested. If was too big for the PM mail
DJ Apolaro
dj apolaro is offline   Reply With Quote
Old 02-28-2007, 02:03 PM   #1973
DJ Apolaro
Hi DJ:
Can you please post the list of itens here?
regards
Eduardo
Old 02-28-2007, 02:08 PM   #1974
dj apolaro's Avatar
Hi DJ:
regards
Eduardo
I am not really an employye of serpents, just a driver/Tech helper. Your best bet is go to the serpent.com web site and It will show you everything you need. Just check out the 720/07 version area.
DJ Apolaro
Old 02-28-2007, 02:17 PM   #1975
Umm, I think you have it backwards. When the front tires are smaller, the front drivetrain will want to turn slower, not faster...of course it's the same with the rear...maybe you're thinking that the actual tire will have to turn faster to keep the car going the same speed???
Luke W is offline   Reply With Quote
Old 02-28-2007, 02:19 PM   #1976
rmdhawaii's Avatar
Okay. I'll keep an eye out for the list of parts.
DJ Apolaro
Sweet! You da man! I'll check it out as soon as I have access to my email. I guess you're ready for the next one.
Old 02-28-2007, 02:29 PM   #1977
Not sure if I'm completely correct, but it looks like the differences in the 720 '07 are: black chassis, nylon adjusting nuts (pivot balls), CVDs up front, adjustable ackerman servo saver, and a "Lemans type" bumper as an extra...
Old 02-28-2007, 02:33 PM   #1978
Derby Bros Racing's Avatar
Also the "upgraded fuel tank with o-ring sealed AFL lid" and the "new hard plastic suspension parts".
Here's what it says on the website:
The Serpent 720 07 in Brief
The new main features of the Serpent 720 '07 are the inclusion of front CVD shafts, extra one way front shaft with lock set, nylon adjustable pivot ball nuts, upgraded fuel tank with o-ring sealed AFL lid, servo saver with adjustable Ackerman, new hard plastic suspension parts and a new black anodised chassis plate.
Derby Bros Racing is offline   Reply With Quote
Old 02-28-2007, 02:34 PM   #1979
1FastSerpent's Avatar
Luke ,
Hows those CVD's holding up? Mine are doing Great...A big Plus added to my car.
1FastSerpent is offline   Reply With Quote
Old 02-28-2007, 02:54 PM   #1980
Originally Posted by 1FastSerpent
Luke ,
The 720 07 will include CVD for the front according to the website.
The description says:
Driveshafts
The 720 '07 comes supplied with the finest Spring Steel driveshafts capable of withstanding constant punishment; these shafts are ultra durable and very stiff allowing you to put all your power to the tarmac. The rear of this car uses dogbones while the front uses the supplied CVD shafts.
I'm not sure what the part number of the "new" CVD (OR if it's even new for that matter). However, here's how the "old" CVDs look like:
http://www.serpent.com/image.php?ImageID=40456&size=350
And the "new" ones that's included in the 720 07 look like this:
http://www.serpent.com/image.php?Ima...68125&size=350
They look different and may be new and the description says spring steel material.
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
