Serpent 720
Old 11-10-2006, 01:43 PM
  #1636
hey, can i ask wot effects would you see tightening, loosening belts on front, back and centre
thanks
bigboss is offline
Old 11-10-2006, 04:22 PM
  #1637
soc123_au's Avatar
Originally Posted by Team Kamikaze
Serpent made a tool to make the adjustment of the centax clutch easier, with this tool you can adjust the tension of the spring externally, part number for the tool is #909598, but a tool to make building the centax clutch easier, I don't think there is one.
http://www.mytsn.com/products/desc.asp?prid=4201
This helps with setting clutch gap.
soc123_au is offline
Old 11-14-2006, 10:02 AM
  #1638
Serpent USA included a hard clutch spring with a sheet recommending various setting depending on the engine being used in the box of my 720. The sheet shows an END PLAY setting of between 0.4mm and 0.6mm, depending on the engine. This seems to me to be excessive as most other documentation recommends a setting where there is barely any movement. Wondering if these numbers are correct or are they maybe off by a decimal point.
calvin is offline
Old 11-14-2006, 10:07 AM
  #1639
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
loose belts are faster but have a larger risk of slipping, slipping will lead to failure. so often you run a loose belt for quals and tighten them a notch for mains.
ammdrew is offline
Old 11-15-2006, 07:59 AM
  #1640
Derby Bros Racing's Avatar
New stuff I saw today from www.mytsn.com ! Pretty cool stuff .
Rear body mount support
Floating body mount for lolas
Derby Bros Racing is offline
Old 11-15-2006, 09:07 AM
  #1641
nigelnuggets's Avatar
and theres my xmas present.
nigelnuggets is offline
Old 11-15-2006, 02:58 PM
  #1642
DS Motorsport's Avatar
Why would a floating rear body mount only for lola"s?
it could have the same positive effect on a touring shell i think.
Think i'm going to try it see if it makes any difference.
Or is it not allowed in the touring class??.
Carbon support looks pretty cool.
DS Motorsport is offline
Old 11-15-2006, 04:12 PM
  #1643
Sow&Steady's Avatar
And mine ... together with the Pro Centax II set I think. Maybe it won't fit the 720 but I'm tempted to resurrect the old 705!
Sow&Steady is offline
Old 11-15-2006, 08:44 PM
  #1644
redsand's Avatar
That floating body mount is really tempting.
redsand is offline
Old 11-15-2006, 11:39 PM
  #1645
Pro centax II? haha i didnt know that fit the 705. cool!
Old 11-16-2006, 12:19 AM
  #1646
M7H
M7H's Avatar
If santa accidentally gives the centax clutch set to you, then send it to me my friend.....
M7H is offline
Old 11-16-2006, 12:31 AM
  #1647
Sow&Steady's Avatar
Naa, if Santa accidentally sends you a S960, send it over to me my BEST friend!
Old 11-16-2006, 01:35 AM
  #1648
Has anyone noticed that on the caberlink mount they have given you more mounting holes for the link?
Nick Simpson is offline
Old 11-16-2006, 03:53 AM
  #1649
Yeah I did... On mytsn there's a picture of all the parts.. more clear there... what i'm wondering is the bolt in stead of the normal hex screw...
_cyclops_ is offline
Old 11-16-2006, 07:26 AM
  #1650
Here's how the floating rear goes in the car...
http://www.mytsn.com/products/downlds.asp?prid=4368
