Old 11-07-2006, 12:22 AM   #1591
Originally Posted by bigboss
hey guys, just wondered if you guys could help
my 720 is pretty much on default set up, bsides yellow springs and suspension on the back is more incline, (more angle)
i just seem to always lose my rear especially on exit of corner, cant put down full power or it will spin
any advice thanks
Can i just ask what Body you are running?
Nick Simpson is offline   Reply With Quote
Old 11-07-2006, 03:34 AM   #1592
Originally Posted by Team Kamikaze
Triton 2 is a very good charger, I have the original Triton and it charges any kind of rechargeable batteries including gell cell/lead acid.
Thanks, appreciate it.
Acid
Acid is offline   Reply With Quote
Old 11-07-2006, 03:38 AM   #1593
Originally Posted by B4
I changed mine to the LM bumper and just used a bench sander to take it down to the same profile as the foam but giving 3mm of clearance for the foam bumper to soak up any impact. You will notice if you look at the LM bumper compared to the original that where it mounts to the chassis there is substantially more material.
Thanks, definitely going to give the LM bumper a try.
Appreciate the info.
Paolo referred to the S720... anyone has info on that?
Acid
Old 11-07-2006, 06:00 AM   #1594
thanks for advice guys
and Nick S, im using Mazda 6 bodyshell
and btw im Mat, the guy who bashed your car a few times last race day back in halifax
bigboss is offline   Reply With Quote
Old 11-07-2006, 06:57 AM   #1595
Small World.......... Ive sent you a PM
Nick
Old 11-07-2006, 08:32 AM   #1596
Sow&Steady's Avatar
Acid
Either I've misunderstood you or you are way left out of time. The S720 is the new Serpent car :-
http://www.mytsn.com/products/desc.asp?prid=4334
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 11-07-2006, 10:28 AM   #1597
Thats the car I got... was just asking, cos Serpent came out with the S710 after the 710.
Thought, they launched a new version of the 720, like before.
Acid
Old 11-07-2006, 11:15 AM   #1598
Acid
Hi Acid,
S-720 is the abbreviation for Serpent 720. Is just that i am lazy
RCtarget, Capricorn, Novarossi, Maxima MX Fuel, Matrix, Xtreme Aero, Avid, Ko Propo, Veytrex Lab, Blast RC, PMR
Paolo M is offline   Reply With Quote
Old 11-07-2006, 12:13 PM   #1599
I am in the final stages of assembling my 720 and cannot find the 5x7 bearing spacer, part # 909514, that fits in the Centax clutch assembly. Can anyone tell me the thickness of this spacer so that I can make a temporary shim pack until I am able to locate the correct part. Any help would be appreciated.
calvin is offline   Reply With Quote
Old 11-07-2006, 12:20 PM   #1600
Originally Posted by Paolo M
Hi Acid,
Thanks Paulo
Just wanted to check if there was a new version of the 720...
Acid
Old 11-07-2006, 12:54 PM   #1601
Team Kamikaze's Avatar
The exact thickness is 0.9mm
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 11-07-2006, 01:21 PM   #1602
Team Kamikaze, thanks very much for your reply.
Old 11-07-2006, 02:35 PM   #1603
wazee's Avatar
does anybody got the combination of the futaba 2.4ghz receiver and the s720?
cutting alway the half of the backplate of the receiver mount is a bit fragile in the end i think.
Does anybody have a solution for mounting it?
wazee is offline   Reply With Quote
Old 11-07-2006, 07:58 PM   #1604
need-4-speed's Avatar
Default CVD woes
First off - let me say that I really like my 720 but......
Has anyone had problems with the CVDs breaking easily? If I just tap a wall the CVD is toast. I know, I know just stay off the walls and problem solved, right? However, I have never seen repeated failures like this, EVER. I have gone through 5 CVDs (left and right combined) with less than 1 hour of track time.
Just to clear the air, I am not a nubie. I have been racing at this particular track for 4 years. I also run the 960 which I'm quite good at if I may. I've used quite a few different cars ranging from Mugen to AE to Kyosho to Xray. None of them has broken a CVD. Hell, there are rookie drivers out there banging up the boards and they keep on going. I happen to be the only Serpent guy out there and also the only one with these failures. It's kinda of a bummer. I was just at the track Sunday (went thru 2 CVDs). Since my car was broken I was watching a guy driving a RRR. He hit the walls countless times and nothing happened. Each time he hit with the front of the car I wispered under my breath, "That would have been a CVD".(referring to myself, of course)
Anyway, I just wanted to see if anyone has had this happen...
need-4-speed is offline   Reply With Quote
Old 11-07-2006, 08:30 PM   #1605
If you're using the stock front bumper setup, then anything you tip/hit will more then likely cost you a few replacement parts... I learned my lesson with the 710... Switch to the lola lower front bumper for the 720 and use the 710 bumper pad... You'll be able to hit almost anything and keep on racing...
RC_Alan
rc_alan is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
