Old 11-03-2006, 04:11 PM   #1576
Derby Bros Racing's Avatar
Originally Posted by bigboss
cheers matey
i'll try it tomoz wen i get myself some new oil
wasted all of it trying
bigboss
No problem man, I hope the steps help....
By the way, on step #3 I initially said to partially turn it 3 turns (now edited for clarification). Well, I turn it 3 times but technically it's only about 1 and a half turns. Just thought I'd make that clear because you don't want the retainer to be all the way closed to let the excess oil out .
Derby Bros Racing is offline   Reply With Quote
Old 11-04-2006, 03:43 AM   #1577
Originally Posted by Serpentd
Thank you for the info dude. I talked to Doug at Serpent USA and he's sending me the updated arms, but I can't seem to find those Mugen upgrade pivot balls to save my soul. Can you point in the right direction please. I like your approach to this problem. Thanks bro!
Hi
Sorry for the late reply but I have been hectic at work...
Anyway, I think 3Racing and KFactory make thes upgrade pivotballs for both Mugen and Serpent.
I got the Mugen ones cos I didn't want to take any chances... slightest toutch on the rear and I loose my toe in... can't have that in a race
The Mugen pivot ball is slightly longer and slightly wider, so it makes for a tighter fit. The only difference is that the ball part is smaller than the serpent one.. so you got to tighten derlin screws in a little more, thats it
Either way, whether you use the Mugen ones or the Serpent ones, you should be fine - Serpent sorted this issue out with all the new kits
The nice thing about going with the upgrade pivot balls is that they are lighter in weight than the original ones...
Hope this helps...
Acid
Acid is offline   Reply With Quote
Old 11-04-2006, 03:51 AM   #1578
Default Serpent S720
Hi Guys
S720.... what is this.. can't find info on mytsn as well...
Can anyone help?
Acid
Old 11-04-2006, 04:14 AM   #1579
Default Info
Hi Guys
One more question:
Have any of you had problems with the front lower bumper (plastic part that connects to the chassis). I have broken 3 of these, already. The part seems to be weak... or is just my driving
Thought about trying the LM Type bumper to solve this problem... has anyone tried the LM Type bumper?
Acid
Old 11-04-2006, 08:49 AM   #1580
nigelnuggets's Avatar
Send a message via AIM to nigelnuggets
if barriers are hit, parts are broken...
wouldnt you rather have like a 5 dollar part BREAK rather than having a 100 dollar chassis be damaged?
just avoid the walls my friend!
Kamikaze Toys and Hobbies. www.kamikazetoysandhobbies.com / www.kamikazercracing.com
nigelnuggets is offline   Reply With Quote
Old 11-04-2006, 08:56 AM   #1581
I agree
But, its not from barriers... its more from rear ending and trying pass
And, to be honest, coming from the 710... the 720 is exceptionally strong...
That was the only part I broke on the car
Acid
Old 11-04-2006, 08:59 AM   #1582
Default Battery Charger
Hi Guys
Can anyone recommend a good charger/discharger?
Thinking of getting the Triton2 - anyone using this? Reason for this, is that it also charges lead acid batteries.
Acid
Old 11-04-2006, 09:41 AM   #1583
ShermanSim's Avatar
Originally Posted by Acid
Hi Guys
One more question:
Acid
I've switch to the LM type bumper with the old 710 foam on top of it.
never had any issue anymore, of course I've always try to avoid hitting anything.
Serpent America, 977 KO Radio, Nova Rossi Engine, Kosmic Fuel
ShermanSim is offline   Reply With Quote
Old 11-04-2006, 10:02 AM   #1584
Team Kamikaze's Avatar
Hi Guys
Acid
Triton 2 is a very good charger, I have the original Triton and it charges any kind of rechargeable batteries including gell cell/lead acid.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 11-04-2006, 12:38 PM   #1585
The bumper is not the strongest to avoid chassis tweak. Don't get me wrong though as I've only replaced mine once after a radio hit and my car went straight to the wall. The bumper cracked in the middle and had to be replaced but I checked the chassis after the accident and it's still perfect. If the bumper was bulletproof, a head on collision could result in a tweak chassis that could be more expensive to fix.
Regarding the pivot balls, the Serpent pivot balls are the lightest available. The initial run of rear arms had issue that caused rear toe problems after a hit (this was sorted out right away with the factory even replacing them for free). There is nothing wrong with the pivot balls at all.
Old 11-04-2006, 06:45 PM   #1586
B4
B4's Avatar
Hi Guys
One more question:
Acid
I changed mine to the LM bumper and just used a bench sander to take it down to the same profile as the foam but giving 3mm of clearance for the foam bumper to soak up any impact. You will notice if you look at the LM bumper compared to the original that where it mounts to the chassis there is substantially more material.
B4 is offline   Reply With Quote
Old 11-05-2006, 10:15 AM   #1587
hey guys, just wondered if you guys could help
my 720 is pretty much on default set up, bsides yellow springs and suspension on the back is more incline, (more angle)
i just seem to always lose my rear especially on exit of corner, cant put down full power or it will spin
any advice thanks
bigboss is offline   Reply With Quote
Old 11-05-2006, 10:48 AM   #1588
Send a message via ICQ to _cyclops_
any advice thanks
Try using a lighter diff oil. Also more toe-in might help.
are you sure the yellow springs in the rear aren't too soft? The chassis might be hitting the bottom....
_cyclops_ is offline   Reply With Quote
Old 11-05-2006, 11:15 AM   #1589
Sow&Steady's Avatar
Without knowing what track you're running on and also what traction you have, I tend to agree with Cyclops, your rear on yellow is too soft. The softest you run on foams should normally be red.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 11-06-2006, 11:27 PM   #1590
B4
B4's Avatar
any advice thanks
I'm running on low/mid traction. Only difference from the base setup is .5 degree more rear toe, 10000 rear diff oil and long ackerman arm.
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
