Old 10-19-2006, 08:18 AM   #1501
Team Kamikaze's Avatar
Originally Posted by eduardo_garcia
Hi guys:
which one is lighter? 802163 802162? aluminium middle shaft or the new SSP middle shaft?
Regards
Eduardo
The Aluminum middle shaft is definitely lighter.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 10-20-2006, 12:03 PM   #1502
Thanks for the answer.....
I'm trying to remove some weight from my 720. I will change the middle shaft and i'm using the titanium main shaft. Do you have any other sugestion for me?
regards
Eduardo
eduardo_garcia is offline   Reply With Quote
Old 10-20-2006, 03:47 PM   #1503
Send a message via ICQ to _cyclops_
regards
Eduardo
Titanium screws work well...
Ceramic bearings also save some wait... do other things and you'll compromize in strenght and other things...
_cyclops_ is offline   Reply With Quote
Old 10-20-2006, 04:28 PM   #1504
which titanium screws do you recomend? serpent does not manufacture those screws.....
Old 10-20-2006, 05:56 PM   #1505
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
EAST made titanium screws for the 710, dont know if they already made one for the 720
buboy28 is offline   Reply With Quote
Old 10-21-2006, 01:38 AM   #1506
I don't use them, but there are different manufactures. You should select the screws yourself. You probably want soms spares too
www.the-border.com had 710 screw set kits, haven't seen them for the 720...
Old 10-23-2006, 07:04 AM   #1507
thamjk's Avatar
Default parts 803178
hi
can anyone tell me the above 720 parts is the 2-speed shaft (spring steel) be used in 710?
Also I have bought this steel pinion 16T 802512. Its a great option part but I notice the clutch bell is wobble badly. Anyone experience this? the clutch bell seems good after I exchange it back to 17T aluminium pinion.
Serpent 710
Nova MAX
3PK
thamjk is offline   Reply With Quote
Old 10-23-2006, 07:50 AM   #1508
Originally Posted by thamjk
hi
Should fit with some dremel work. The left nudge for the pulley screw is more to the left or right....
The 16T is to 'small' to manufacture. It's adviced to not use it. Some drivers also complain that it will not give more bottom speed because you'll only generate wheelspin.
I'm not sure, but i've heard that the 16T being to small to manufacture with good quality and durability. It's the reason why the 720 changed it's ratio a little, so you don't need the 16T anymore... but i'm not sure...
Old 10-23-2006, 08:37 AM   #1509
thamjk's Avatar
which part of the shaft that i need to trim it off. It looks compatible to 710 at the way it looked. i just need a confirmation before purchase this part.
It looks good with 3porter. just because of thie little problem else it will be perfect.
Serpent 710
Nova MAX
3PK
Old 10-23-2006, 09:52 AM   #1510
hi
It will fit the 720 without any modification.
Old 10-23-2006, 11:05 AM   #1511
Julius's Avatar
The spring steel 2-speed axle will fit both the 710 and 720.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 10-23-2006, 12:25 PM   #1512
banky71's Avatar
Will the 710 universals fit the 720? I keep losing front dogbones and want to change over to universals to solve this problem. If not where can I find the universals for the 720?
banky71 is offline   Reply With Quote
Old 10-23-2006, 12:28 PM   #1513
Derby Bros Racing's Avatar
Yes, the 710 universals fit the 720 (same universals).
Derby Bros Racing is offline   Reply With Quote
Old 10-23-2006, 12:52 PM   #1514
banky71's Avatar
Thanks....
Old 10-23-2006, 01:18 PM   #1515
madbeats's Avatar
Default Fully hopppp upppp
Take alook @ this 720
Serpent 966/720 Mugen MTX4R Xray NT1-Mugen MTX-4 Knack R conversion Hong Nor X1CR
madbeats is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
