What radio gear do you use? why? thread >
Old 04-01-2006, 05:34 PM
  #31
Riketsu's Avatar
Trader Rating: 33 (100%+)
double post
Riketsu is offline
  #32
Riketsu's Avatar
Originally Posted by Artificial-I
Spektrum is actually slower. It adds a delay to all radios actually.
Correct, hence why the new Pro Spektrum system reduces that "lag". And why some pro's havent switched over.
Riketsu is offline
Old 04-01-2006, 05:58 PM
  #33
maskedrider's Avatar
maskedrider is offline
Old 04-01-2006, 11:15 PM
  #34
Chris West's Avatar
I didnt notice any difference between the Spektrum and PCM/PPM, it felt the same, but there is a difference between the HRS and standard Spektrum
Chris West is offline
Old 04-01-2006, 11:29 PM
  #35
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
i recently made a switch to specktrum and as far as response time i dont feel any slowdown at all , i know the first batch of spectrum system had some issues with slow response time but it has been worked out, i am really happy with specktrum
Tag is offline
Old 04-02-2006, 03:23 AM
  #36
Ridder's Avatar
Originally Posted by fritzD
DO you guys use exponentia rate for your TH? I use + exp for the steerin. I'm just not sure what for throtle.
I have a Graupner/JR XS-6, which is a synth Tx and Rx.
Good price and no crystals.
I use negative exponentional rate for steering.
Then I can make tiny adjustments on the straight without going from one side to the other.
I keep the throttle lineair.
Ridder is offline
Old 04-02-2006, 08:05 AM
  #37
fritzD's Avatar
i see... so that's why KO is not planning on making spektrum like modules
fritzD is offline
Old 04-02-2006, 09:06 AM
  #38
rmdhawaii's Avatar
I'm holding off on a new radio until the Futaba 2.4G comes out...
rmdhawaii is offline
Old 04-02-2006, 10:58 AM
  #39
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
The only problem , how long will we be holding off. Could be a year before it comes out. BTW the new futaba spektrum PRO HRS unit is now available. .2 latency instead of the .5 added.
Artificial-I is offline
Old 04-02-2006, 11:20 AM
  #40
Moderator
I dont really notice anything either. But it is there. An extra step in the chain of response.
Old 04-02-2006, 11:23 AM
  #41
Moderator
With the new pro spektrums @ .2 you shouldnt notice much. But @ .5 you can.
Old 04-05-2006, 09:46 PM
  #42
Chris West's Avatar
the Futaba HRS Spektrum is at 2ms and the pro systems are at 3ms
Old 04-06-2006, 05:40 AM
  #43
hav_lova's Avatar
I use a Futaba 3PK and got spektrum a couple weeks later, it makes life just so much more simple. I really like being able to turn my radio on in the pits. I'm split between Futaba and KO servos.
Dad uses a DX3, its nice but it lacks features.
hav_lova is offline
Old 04-19-2006, 06:47 PM
  #44
fritzD's Avatar
guys,
does anybody who have a spektrum exerienced a slight glitch? or is it really 100% glitchless
fritzD is offline
Old 04-19-2006, 06:50 PM
  #45
Moderator
In theory they shouldnt , but some had technical difficulties so they glitched quite a bit. You could send them in they would apply fixes. The latest version should be truly glitchless. But otherwise it is a glitchless system. I have the old version and I dont think Ive ever experienced a glitch.
But yeah , eletrical motor noise and metal to metal noise is a thing of the past with these.
