Old 03-27-2006, 03:44 AM   #16
fritzD's Avatar
Send a message via Yahoo to fritzD
ohh.. okay.... hehehehehe...
fritzD is offline   Reply With Quote
Old 03-27-2006, 07:12 PM   #17
with belts you get wide range of gear ratios, with shafts you get none.
jake alton is offline   Reply With Quote
Old 03-27-2006, 07:51 PM   #18
integra evan's Avatar
Send a message via AIM to integra evan Send a message via MSN to integra evan
You can still adjust gear ratios on a shaft driven car.
integra evan is offline   Reply With Quote
Old 03-28-2006, 02:03 AM   #19
fritzD's Avatar
of course you can but for belts you can change the number of teeth to just about any of the pulleys... and this affects the handling greatly..
Old 03-28-2006, 03:00 PM   #20
My bad! I assumed, shaft was a shaft and belt had teeth and cogs. I forgot about the little spyder gears that are easily changable.
Old 03-28-2006, 09:04 PM   #21
No problem. Although belt is definitely more adjustable (like mentioned above), you can still tweak gearing of shafts...I constantly tweak the ratio on my RS4 3 EVO (shaft).
Belt Drive vs shaft drive vic88my Nitro On-Road 16 11-10-2007 08:26 AM
shaft drive vs. belt drive plz help pH1L Rookie Zone 1 06-07-2007 05:32 AM
Belt drive versus shaft drive...pros and cons of each? AttackDonut Rookie Zone 21 01-02-2005 05:23 PM
Belt drive or Shaft Drive tc3wood Electric On-Road 4 12-03-2004 07:57 AM
Shaft Drive or Belt Drive? dino.tw Nitro On-Road 109 05-25-2004 11:04 PM
