Stripped screw with locktite >
Like Tree4Likes
  • 1 Post By Roelof
  • 1 Post By nitrodude
  • 1 Post By 1/8 IC Fan
  • 1 Post By Zerodefect
Old 08-13-2020, 08:47 PM
Naquoc's Avatar
Default Stripped screw with locktite
Hi,
When building the car, I applied too much locktite and now I need to remove some screws, I actually stripped them. I tried heat (solder iron), speed out and grabit extractor with no luck.
Does anyone has better solution to remove stripped screws?
Thank you so much.
Naquoc is online now
Old 08-13-2020, 11:57 PM
Roelof's Avatar
Cut a slot in it with a dremel and a thin grinding disc, heat up the screw with a solder iron and unscrew it with a flat head screwdriver
MikaR likes this.
Roelof is offline
Old 08-14-2020, 01:23 AM
Sir 51D3WAYS's Avatar
Using extreme care and precision, drill out the screw using a 3mm bit. Aim for the exact center.....
You may want to replace the screw below it as well...
Sir 51D3WAYS is offline
Old 08-14-2020, 05:00 AM
1/8 IC Fan's Avatar
Trader Rating: 96 (100%+)
And now we have two threads.....
Stripped screws with locktite
1/8 IC Fan is offline
Old 08-14-2020, 05:48 AM
the rc guy's Avatar
you need to apply more heat to screw to break the loc tites hold. not sure what you have on hand but if you have it find a piece of copper use your Dremel and shape it like the drilled head heat copper up and break the loc t hold.I use vise grips and a propane torch even a turbo jet lighter will do.not sure what type of loc T you used but they all have heat ranges to make them release grip look it up get the copper 20 degrees hotter b4 applying to screw head.
B4 you do all this use ur dremel and the rectangle cleaning stone to made the cut off wheel a small dis so you dont damage ur cf chassis.
the rc guy is offline
Old 08-14-2020, 07:10 AM
Bsthetech's Avatar
Somethings up with Blue Loctite these days. I used it for years without a problem and then this year I've had two screws I couldn't get out. An EZ Out worked like a charm in one case. I've been using Purple Loctite ever since without a problem. If you read the specs it's the one we should be using for these little screws anyways.
Bsthetech is offline
Old 08-14-2020, 07:20 AM
Use a drill slightly larger than the screw, drill it right on center. Once the drill cuts through the head, the head will just fall off and you're done. I've had to do it a few times. Much better than putting a slot on it.
Sir 51D3WAYS likes this.
nitrodude is offline
Old 08-14-2020, 07:39 AM
the rc guy's Avatar
why not just use a left handed drill bit 5/16 should work.
https://www.richtoolsystems.com/scre...=Ad+group+%231
Old 08-20-2020, 03:23 AM
1/8 IC Fan's Avatar
Because, after you get past the head, it will still not have enough torque to break out the shank from the loctite. If it did not break out with an Allen Head Wrench or driver that tiny bit won't do much good.
nitrodude likes this.
Old 08-20-2020, 04:07 PM
Zerodefect's Avatar
Once the aluminum piece and carbon plate are apart, you'll be able to grab what's left of the bolt with vice grips. 3mm might be plenty to grab. Heat the threadlock with a torch. It'll melt at high Temps into a nice lube sometimes.
Zerodefect is offline
Old 08-20-2020, 05:06 PM
Trader Rating: 72 (100%+)
I use screw extractors, works every time
martind1318 is offline
Old 08-25-2020, 01:55 PM
YoDog's Avatar
Trader Rating: 28 (100%+)
Not with a flat head screw which is what he has. There will be nothing left grab onto if it's just drilled out. The slot + heat is probably the only way.
YoDog is offline
Old 08-25-2020, 02:07 PM
the rc guy's Avatar
theres many different ways to get the screw out.heat is the 1st gotta break the loc tites grip.
Old 08-29-2020, 12:14 AM
1evo RRR Driver's Avatar
best way was the 1st suggestion slot it with a dremel and take screw out with flathead
1evo RRR Driver is offline
Old 09-04-2020, 02:50 PM
GB_TimD's Avatar
I have drilled out the whole screw to remove it.
GB_TimD is offline
