Home made tyre truer? >
Old 03-23-2006, 02:38 AM
Helix70's Avatar
Default Home made tyre truer?
Has anyone made a home made tyre truer (1/10 nitro foam)? Can you give me any hints? What speed is ideal to spin the tyre? Any better cutters than others? I don't need automatic, just accurate and effective.
My thought was to use a stock 540 motor with a small pinion to drive a belt to a drive shaft with a larger gear, with guide shaft in parallel (raised and lowered with a thread for accuracy/repeatability) to run a cutter along.
Any tips/designs/advice/critcisms?
Josh
Helix70 is offline
Old 03-23-2006, 03:46 AM
Trader Rating: 15 (100%+)
You are going to need a stock motor something more then a 540. For the gearing I used the biggest 48 pitch gear that I could find and and a pretty small pinion. For the cutter I used a Ryobi one inch sanding tube around a one inch dow rod. I still have it if you want to pay the shipping it's yours at no extra charge.
THE DOCTOR is offline
Old 03-23-2006, 03:51 AM
Helix70's Avatar
Thanks! Good idea using the sanding tube. Got a photo of the setup? Any idea how much postage is to Australia from there? What does it all weigh?
Cheers,
Josh
Helix70 is offline
Old 03-23-2006, 07:05 PM
Trying to show a pic but didn't work.
Old 03-23-2006, 07:08 PM
Cheers,
Josh
I sent you a PM. Check your messages.
