team magic 1/10 setup system
does anyone know if you can but those wheel hand nuts seperately???
there are the nuts you tighten by hand and hold the wheel shaft onto the setup system. i have two cars one with a imperial wheel shaft and the other with metric.tm do make an imperial setup system and metric but i dont want to buy two seperate systems. any help would be appreciated :) |
anybody ?????
there are the nuts you tighten by hand and hold the wheel shaft onto the setup system. i have two cars one with a imperial wheel shaft and the other with metric.tm do make an imperial setup system and metric but i dont want to buy two seperate systems. any help would be appreciated :) hope that helps |
yes we can get them, so can your aus distributor. go to the customer center on the Team magic site.
we just need to know what system you have english or metric. |
bag
dennis when will the 8th hualer bags be in :tire: :)
we have had 1/8th hauler bags a while now. We are at the end of them though I think we have 3. I expect those to be gone tomorrow. Our next batch won't be available for a while probably middle of may as the factory it tooling up a new run of them and they are out.
willie you should go to the website and look around. you would be suprised what we stock. there is a dealer page there to. |
if anyone is deciding on getting a 1/10th setup system then i strongly reccomend the team magic one.the quality is unbelievable and its not too expensive either.
i like the way that team magic always puts a lot of effort into the little things because its always the little things that make a big difference. one good example i have found on the setup system is that you can actually acheive a realistic ride height with the car on the system and because of this you can also measure the toe-in/out front and rear without taking off the body posts!!! i have uses other setup systems and the plastic thing that you put across the top to measure toe-in/out would always foul on the body posts but this is not the case with the tm setup system!! btw i am not sponsered by tm.i am speaking from experience with using the product. keep it up tm!!! :nod: :nod: |
