Kyosho KE25 factory needle setting?
Hello everyone, I have been searching high and low for the factory needle settings on the ke25 motor. Can someone please enlighten me. Many thanks and may you have a nice day!!
You are better off to learn how to tune an engine. Be sure you can make it start and from there the engine will tell you how it runs and what needs to be adjusted.
Otherwise on kyosho.com you can find a download page with all the manuals.
I tried looking on the kyosho website and couldn't find the needle settings. If I describe what the motor is doing would you give me some pointers?
Ok I finally found the needle settings, I was trying to look for the settings in the inferno gt2 manual but I guess I just had to look in the ke25 manual. No wonder it was running badly the needle settings were way off. If anyone wants to know the hsn is 3.5 turns out from closed and the lsn is 2 turns out from closed.
So the engine was running.....
Again, the factory setting is no good/optimised sttting. Please learn how to tune your engine.
When as an example changing the exhaust the back pressure will change and with that also the tuning of the engine,
That's like telling someone who doesnt know how to read that they need to learn how to read, I'm trying my best bro thanks for the wonderful advice!!! Glad that you are so informative thanks!!!
Do not get me wrong, people asking for factory settings are most of the time the people who can not tune. If you can tune an engine there is totally no need for a factory setting. People who can not tune an engine are the ones that do not get the best out of it and could be ruin their engine. I only want you to get the best out of your engine.
The guy was just asking needle settings..
For an engine that seemed to be running but not good. With knowledge of how to tune no factory setting is needed and finally you will end up with a good running engine. I never rely on a factory setting, they can be far off and with a different exaust even go to lean.
