Old 03-22-2006, 03:44 PM   #16
Orfeous's Avatar
Send a message via ICQ to Orfeous Send a message via AIM to Orfeous Send a message via MSN to Orfeous Send a message via Yahoo to Orfeous
water isnt a good choice for cleaning i would use a alcohol of some kind and then lubricate with after run oil or something.. maybe methanol or how it spells
Orfeous is offline   Reply With Quote
Old 03-22-2006, 03:47 PM   #17
Orfeous's Avatar
Originally Posted by Ivan Dickson
How often do you suppose to clean your motor if you race a few times.
if you ask me..? i dont know how many times or how often to clean the engine.. maybe every race? im totally new to this
Old 03-22-2006, 06:26 PM   #18
You wonn't go wrong if you clean it every race. If you don't clean it after every race/day of running, take out the fuel line and run out the rest of the fuel in the block, then use afterrun to avoid rust buildup on the crank.
havy
havy is offline   Reply With Quote
Old 03-23-2006, 07:14 AM   #19
Orfeous's Avatar
after each day racing with the motor im blowing with compressor air on the car everywhere and outside the enginge.. etc..
then after that i spray 5-56 (similair to WD40) in the carburettor and in the hole on the top.. then i put the car on starterbox and let it spin for some seconds..
Old 03-23-2006, 07:44 AM   #20
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
havy
Why not just run it again with the fuel lines in tact so you can also clear the gas-tank and lines?
But this is good to do. After your motor runs out of fuel, there is always fuel left. Go bring back to the starter box and try to start it and get the rest of the fuel out of the system. I also normally plug my finger over the exhaust a few times to help push air through to help gather the rest of the fuel.
Nitro Fuel attracts moisture. I would also purchase some after-run oil to be safe.
Artificial-I is offline   Reply With Quote
Old 03-23-2006, 10:05 AM   #21
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Thumbs up
Thanks to everyone for the feedback on how often to clean a engine.
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is online now   Reply With Quote
Old 03-23-2006, 11:38 AM   #22
Orfeous's Avatar
Gonna take my engine to a friends job tomorrow and he will help me to show how i disconnect everything and cleaning it and reassembly.
so i will learn.
Old 03-24-2006, 07:10 PM   #23
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
I suggest to take it apart after each race or each time it sees fuel. Using after-run oil after racing is not enough. I was told to stay away from using alcohol because it contained water. Some fellow racers said they cleaned their engines with WD-40, then used after-run oil upon re-assembly.
Riketsu is offline   Reply With Quote
Old 03-25-2006, 04:13 AM   #24
Orfeous's Avatar
cleaned my engine yesterday.. it looked very cleaned and beutiful inside.. at the main engine layer.. and all the other parts was very shiny and great.
so i didnt cleaned them. just cleaned the outside with 95% etanol so its shining again
i also saw that the engine gots a lot of tuning possibilitys
more of that in another thread.
Old 03-25-2006, 08:37 AM   #25
Moderator
Isopropyl Alcohol (rubbing alcohol) contains water.
Denatured Alcohol does not or at least does not create rust as easy.
Old 03-25-2006, 08:55 AM   #26
Orfeous's Avatar
95% etanol is denaturated alcohol.
Old 03-27-2006, 07:56 AM   #27
Default cleaning the carb
do i have to dismantle all the tuning screws every time i clean the engine
mr.TUNED is offline   Reply With Quote
Old 03-27-2006, 07:58 AM   #28
Riketsu's Avatar
Its up to you. Some people do it some people dont. I dont do it since I messed up the setting of my zx12 by doing this. I only clean the carb superficially and I dont even try to take it off the crankcase.
Old 03-27-2006, 03:33 PM   #29
Orfeous's Avatar
i'm changing the centax clutch shoe also in this cleaning
i think the shoe is yellow or white.. didnt remember
Old 04-17-2006, 06:44 PM   #30
Tweak Hobbies's Avatar
Default Stuck!
Hi, was hoping to get help with my stuck cylinder. No amount of heating or freezing or soaking would seperate the liner from the crankcase. My engine is a Sirio AAC .12 maybe because its an alluminum to alluminum bind? Is this hopeless?
Tweak Hobbies is offline   Reply With Quote
Cleaning Engine How Often? oggietiu Nitro Off-Road 5 07-15-2008 06:32 AM
Cleaning 0.21 engine brianr34 Nitro Off-Road 6 04-20-2008 11:30 AM
Cleaning an Engine? LosiSuperTruck Nitro On-Road 1 09-04-2005 05:15 PM
Cleaning an Engine LosiSuperTruck Electric Off-Road 1 09-04-2005 03:25 PM
engine cleaning tip rcabj Onroad Nitro Engine Zone 3 04-18-2004 08:34 PM
