Old 12-12-2002, 05:51 AM   #1
Default afterrun oil
would 3 in one oil or plain motor oil be ok for lubing the engine before storage?
wahturi is offline   Reply With Quote
Old 12-12-2002, 06:24 AM   #2
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: afterrun oil
yes, any metal protection fuild will do but keep your engine away from WD40
Manticore is offline   Reply With Quote
Old 12-12-2002, 08:30 AM   #3
nova racer's Avatar
some people including I use mobil 1 0w-30 and WD40 mixed 50/50 with a bit of z-max added to help break up any carbon deposits
Yes Z-max works at home like it does on Tv
nova racer is offline   Reply With Quote
Old 12-12-2002, 02:35 PM   #4
popsracer's Avatar
Default After run Oil.
Wahturi;
I wouldn't just use regular (Automobile) Motor oil. It may gum up the inside of the engine over time. Marvel Mystery Oil is the same thing as the Prather after run oil. I've been using it for 3-1/2 years now and my motors are always spotless inside. Marvel won't gum the inside of your engine up either. Found this out when using Air Tools.
popsracer is offline   Reply With Quote
Old 12-13-2002, 05:25 PM   #5
theRED5's Avatar
Thumbs up
Marvel Mysery Oil.
I [I]AM [/I]the Driver !
Murnan Modified Motors
Mugen MRx4
Rocket Science Fuels
Auto Racing, Mountain climbing, and Bull fighting are the only true sports, all the rest are just games.
theRED5 is offline   Reply With Quote
Old 12-13-2002, 07:09 PM   #6
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
A little bit of Microlon each time won't hurt, either.
eddiethefish is offline   Reply With Quote
Old 12-13-2002, 07:31 PM   #7
Manticore's Avatar
microlon is not for afterrun. it is way too expensive for this purpose !!
but i use microlon to mix with fuel foradditional lube.
Old 12-13-2002, 07:32 PM   #8
Manticore's Avatar
by the way, WD40 is corrosive to metal. I have no idea what is the effect of mixing WD40 with engine oil.
Old 12-13-2002, 07:49 PM   #9
Any volunteer to find this out for Manticore? he he, I'll have to opt out.
Old 12-13-2002, 08:50 PM   #10
popsracer's Avatar
Default Home Brew after-runoils
Guy's;
If YOU can think of it, then so has somebody else. If Home brew after-run oil was the way to go then we would ALL know about it.
Stick with the Marvel Mystery oil of any of the Hobby brands of after run oils. Most other types of Automotive oils will gum up the insides of your engines. ALSO don't add Marvel to the Fuel. It will make your engine run MUCH hotter. (tried it long ago)
Old 12-13-2002, 09:48 PM   #11
Registered User
Send a message via AIM to bbntc3
I just use ATF,(Automatic Tranny Fluid), sometimes I add alittle Marvel oil to it, if I have it. I think the boat guys has used ATF for years with super results.
bbntc3 is offline   Reply With Quote
Old 12-13-2002, 09:55 PM   #12
Team_Akina_1's Avatar
Send a message via AIM to Team_Akina_1
Yes, I was saying the same thing to. I use WD40 on the door to stop sqeaking, and notice some rust on it. WD40 also smell bad and atracts a lot of dirt/dust. On the safe side, stick to marvel or Prather after run oil.
Team_Akina_1 is offline   Reply With Quote
Old 12-13-2002, 09:55 PM   #13
Manticore's Avatar
right, ihave been using ATF from AC Delco. great results.
Old 12-13-2002, 10:08 PM   #14
sparksy's Avatar
Trader Rating: 14 (94%+)
WD40 will also eat the comopound that JP and others use for their crank port ramp. Seen it happen before.
I use the novarossi "Special oil"
sparksy is offline   Reply With Quote
Old 12-13-2002, 11:59 PM   #15
Registered User
Companys use compounds inside RC engines, to build up runners for cranks, timing and stuff? I have worked with nitro and alky for years and I am a engine rebuilder by trade. I have never seen anything, compound wise that will hold up to alky, or nitro. I have never seen any compounds used in Rody RB mods or Richey power. It will sooner or later break down or come apart. WD 40 seems like it draws moisture or something, if you use WD 40 in rc engines the crankshaft will rust up over night.
