Old 12-11-2002, 09:08 PM   #1
Send a message via AIM to Saleen S7
Default kind of tire
what kind of tire should i get for my Nitro RS4 3 type s. im a rookie so be gentle lol
Saleen S7 is offline   Reply With Quote
Old 12-11-2002, 10:51 PM   #2
popsracer's Avatar
Default Check this thread out
Saleen S7;
There was a good thread about tires for parking lot racing a few weeks ago. Go back a few pages and look for "Tire Choice for Parking lot racing"
popsracer is offline   Reply With Quote
Old 12-12-2002, 03:04 PM   #3
i would use foam tires if you can they are unbeatable in performance
if you must use rubber i have had good luck with sorex tires before yokomo werent bad either i used hpi insets with both
hpi x-pattern tires are great for playing
ive been kinda wanting to try the medial pro tires that dont use an insert they look like they would last a while
jason102276 is offline   Reply With Quote
Old 12-12-2002, 07:24 PM   #4
RClover's Avatar
what tyre are you running? what's the combination? 42 Front 40 rear?
I play at a parking lot which is quite bumpy and the surface is rough...
thanks
RClover is offline   Reply With Quote
Old 12-12-2002, 07:37 PM   #5
modellor's Avatar
Just stick to rubber tires. For that type of surface the Proline V-Rage work pretty well.
modellor is offline   Reply With Quote
Old 12-12-2002, 11:00 PM   #6
Send a message via AIM to 2Hard2Handle
i think the rs4 3 comes with the x patteren tires so it sould be a great tires cuz my bro got some and it havent been tore up yet
2Hard2Handle is offline   Reply With Quote
Old 12-12-2002, 11:37 PM   #7
popsracer's Avatar
Default Medal Pro tires
I have some Medal Pro (IAS/AIS?) tires in soft compound and the only thing that I could get them to work on was concrete with my electric car.
I don't know of another single person that uses them.
My top 3 tire choices are;
Sorex: 36R's. Work good hot or cold. Especially on sealed asphalt. Sorex tires mount very nice.
Yokomo: 138G and 138GF's. A good rough asphalt tire.
Take-Off: 27CS's. Good all around tire. Great on concrete.
My Comments; ( I would probably not buy these myself anymore)
Pro-line: S-3's. Great grip, wear very fast. Great on concrete. Hard to mount cleanly.
Pro-line: S-2's. Fair grip, better wear. Better on electric cars.
HPI: "Pro" compound Tires. Fair grip, wear fast.
HPI: "R" series tires. Better grip, way too narrow of a temperature range for each compound.
Inserts;
I like to use HPI inserts in all of my tires. Great selection of insert hardness. (5)
Old 12-13-2002, 10:52 AM   #8
i use mugen fast foam tires 40 front and 40 rear
Old 12-13-2002, 08:04 PM   #9
RClover's Avatar
Default Me too...
ahh...i am running the same compound 40 front and 40 rear but they are Ennetti foam tyres. I found the handling is good at corners.
But one thing tough, the rear tyres are wearing faster than the front tyres...i am running 25T middle-side pulley in my V-1-R.
Perhaps i had some wheel spin at the sweeper when entering and the outer edge of rim and tyres rubbed and chipped (like dog bite). the rear tyres are now 3-3.5mm thinkness.
But, I had my camber set at -5 already, its max...!!!
Old 12-13-2002, 08:43 PM   #10
popsracer's Avatar
Default Foam tire wear
RClover;
The Chipping/Chunking is caused by hitting the boards with the sidewalls of the tires. Some people put CA on the sidewalls to try and stop the chunking.
The Rears wearing more than the fronts is normal. Try going to 42 shore all around and adjust your set-up for more steering if you need it. Always try and run the hardest compound that you can and still have decent traction. This will help the wear problem.
Old 12-13-2002, 09:47 PM   #11
Team_Akina_1's Avatar
Send a message via AIM to Team_Akina_1
Default Re: Medal Pro tires
Im also running a set of 138G med. They works great of rough asphalt, and provide acceptable traction. I'm also running on 40 sh all around on ellgi foam, I will start using 45 and 42 on the next race. BTW has anyone run hard yokomo 138ghz?
Team_Akina_1 is offline   Reply With Quote
Old 12-13-2002, 11:00 PM   #12
popsracer's Avatar
Default Yokomo 138G's
The Yokomo 138G's are indeed one of the best Rough asphalt tires availible. The "F's" work when the track temperature exceeds 100.F and the "H's" 120.F and above. The "F" & "H" compounds work really well in Nitro cars because they tend to heat tires up more than an Electric car.
For Smooth/sealed Asphalt; Sorex's are the way to go. The 36R's are the best all around for cool to hot weather (65.F to 120.F).
The other Sorex compounds don't seem to have as much grip as the 36R's when used on a Nitro car.
Old 12-13-2002, 11:08 PM   #13
popsracer's Avatar
Default Yokomo tires
Team_Akina_1;
I see that you are in Sunny CA.
It is probably too cold this time of year to be able to use the 138GH's. The GF's should work as long as the Sun stays out to keep the track warm. Otherwise for overcast or evening racing, I would use the 138G's. If it's really cold (below 60.F), I've had good luck with the 136M's, but they will overheat quickly in warmer temeratures.
Take-Off tires are about equal in grip to the Yokomos. The 27CS compound is probably equal to the 138G. But the Take-Offs will work well on Concrete and Smooth asphalt where the yokomo's will not.
Old 12-14-2002, 01:36 AM   #14
RClover's Avatar
Default Re: Foam tire wear
RClover;
thanks for the tips...i just got some UFRA foam tyres...they are 42s and 40s...the foams looks a little softer than Ennetti and Ellegi ones...hope they are much durable...
Old 12-14-2002, 01:47 AM   #15
Brett's Avatar
Ennetties are shit foams
sorex and kawaharas are good foams
just a bit of experiance
Brett is offline   Reply With Quote
wat kind of rc is this mcm6969 Rookie Zone 1 06-01-2008 05:10 PM
What kind of car is this nudge2325 Australian Racing 1 11-24-2007 07:35 AM
what kind of tires?? tire info. signal21 Rookie Zone 2 03-04-2006 02:56 AM
What kind of car is this? Aoplayo Chat Lounge 5 01-18-2006 08:27 PM
? on what kind of tire truer to buy??????? carpet_killa Electric On-Road 9 12-27-2001 12:25 AM
