Old 03-17-2006, 03:16 PM   #1
Trader Rating: 15 (100%+)
Default Can't get the batteries to charge!
I was using my Novak on the NiMH setting at 1 amp. No matter what I set the peak setting at it would only charge for about 200 seconds. I then lowered the amp setting to .7 amps and it did the same thing.
Now I just bought the hobbico field charger made for charging the receiver and transmitter packs but it does the same thing. I thought that the battery was bad so I just got the Orion 1400 pack and it is doing the same thing.
Any thoughts???
THE DOCTOR is offline   Reply With Quote
Old 03-17-2006, 03:23 PM   #2
GrandeGixxer's Avatar
Is it possible that the pack is already charged? Not trying to be funny, just tryng to help.
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 03-17-2006, 03:38 PM   #3
I wish that it was the case. I discharged it and let it cool but it does the same thing.
Old 03-17-2006, 04:05 PM   #4
Chris West's Avatar
Send a message via MSN to Chris West
if your charging off a car battery that could be flat, this happens to me when my car battery goes flat
MUGEN SEIKI | NINJA | SANWA
Chris West is offline   Reply With Quote
Old 03-17-2006, 04:27 PM   #5
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Packs can false peak sometimes.
Reset the charge a couple of times to get it to take it , it should then get past the funky start and will charge normal till its true peak.
False peaking occurs when you havent used pack in awhile or its a new pack.
When a pack starts to get warm this is when there charging correct and should soon peak. Be sure to not let a battery get over 120F or so just in case that charger is acting funny. Thats when it should stop if not its charging too much.
Also picking up and moving a battery around can also get the charger to false peak due to the spikes that happen when the connection is moved around.
Good luck. Let us know.
Artificial-I is offline   Reply With Quote
Old 03-17-2006, 07:11 PM   #6
I will give it a try off of a power supply. I have been racing rc for 20 years and this one has got me??
Old 03-17-2006, 08:16 PM   #7
Moderator
What charger is it?
Old 03-17-2006, 10:36 PM   #8
Rapid Roy's Avatar
You can also try cycling the pack 4 or 5 times to wake it up.
Rapid Roy is offline   Reply With Quote
Old 03-18-2006, 11:16 AM   #9
Originally Posted by Artificial-I
What charger is it?
A Novak millenium and the Hobbico field charger. The Novak is not the Pro model. The Hobbico is brand new.
Old 03-18-2006, 11:17 AM   #10
What chargers are you guys using?
Old 03-18-2006, 11:24 AM   #11
Moderator
Duratrax ice.
I think you just need to keep restarting the charger after a few times it should go.
Old 03-18-2006, 12:00 PM   #12
Roger's Avatar
On the novak charger, change your voltage threshold to the lowest settings. The novak non-pro version is automatically set at 12mV which is usually used for Ni-Cd.
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 03-18-2006, 02:28 PM   #13
Rapid Roy's Avatar
I just use a combo wall charger for both Tx and Rx, but I do cycle occasionally with my Tekin BC112c and DIS350 combo. I use 1 amp, although sometimes it keeps wanting to false peak, so I drop it to .7 amp.
Old 03-20-2006, 06:33 AM   #14
The wall charger I have is for Ni-cads 6 volts not NiMh, will it still work?
Old 03-20-2006, 09:21 AM   #15
Moderator
NICAD is going to overcharge your NIMH battery.
Have you tried just restarting the charge process yet? I had an old battery just yesterday only take 200mah and it barely would go up in voltage....went up , then went immediatly flat , then started dropping.
I said watch this , restarted it just once and bam....it stayed flat then 5 minutes later started to slowly climb and I was about to get 1200mah into it. My pack was a 1400 mah pack. Worked perfect!
Id really like to hear your results , this is what most everyone does or suggests. Just try the recharge and it should take.
Best way to charge batteries? rcrevolution Electric Off-Road 3 08-01-2008 12:25 PM
How to charge batteries? techrix Singapore R/C Racers 4 07-31-2008 12:42 AM
Batteries holding charge adrictan Radio and Electronics 0 06-10-2008 08:51 AM
Cant charge my TX batteries?? TRFTIM Electric On-Road 3 01-08-2007 02:53 PM
How do you charge your different types of batteries? performula Electric On-Road 8 01-21-2003 08:24 PM
