Old 03-13-2006, 07:22 AM   #1
Orfeous's Avatar
Send a message via ICQ to Orfeous Send a message via AIM to Orfeous Send a message via MSN to Orfeous Send a message via Yahoo to Orfeous
Smile Serpent Vector
Hi everyone!
To make the story short.. i had a BMT Active 95R for long time ago.. (1997) and my father had a Serpent Vector and he just run to brake it in.. then the car has layed in the store for some years.. 9 years? so now my father has given me the car to let me drive because he have no time for the sport :P
so the car is mine now. So i have turned the car apart for cleaning because it doesnt seems so clean to me. I want some hints and tips how i can "tweak" the car.. like options and modifications. i got the standard Mega SX21 EV1 engine. Futaba S9402 Servos, Futaba 3PJ radio.
Im using the Serpent 50W Blue shockoil with standard silverspring for medium suspension. Everything else is standard..
Sorry for my english.. but i hope you guys/girls understand. I got some pictures of the car that you can see if you want. http://umea.mine.nu/~anton/gallery/
Hope someone can help me.
/Anton (From Sweden)
Orfeous is offline   Reply With Quote
Old 03-14-2006, 08:48 AM   #2
M7H
M7H's Avatar
Well I tried to help you on the TSN forum.....
Serpent
M7H is offline   Reply With Quote
Old 03-14-2006, 09:01 AM   #3
Trader Rating: 4 (83%+)
Orfeos:
I have a ton of parts for that car new and used parts,from chassis to shocks,let me know if you are interested and i can give you a great deal on everything i have ,PM me and ill give you a list of what i have for that car...
Roniel_R is offline   Reply With Quote
Old 03-14-2006, 09:39 AM   #4
Orfeous's Avatar
M7h, yes i know.. thanks
Have been out in my store now and cleaned chassiplate, bumper, and the whole rear package, and some other parts
I read that i should use a sandpaper and sand the surface under the engine mount brackets to get a better contact with the chassi material to make the heat from engine spread little better.
Old 03-14-2006, 09:40 AM   #5
Orfeous's Avatar
Originally Posted by Roniel_R
Orfeos:
Sounds nice
Old 03-14-2006, 01:45 PM   #6
M7H
M7H's Avatar
Buy an engine monoblock....
http://www.mytsn.com/products/desc.asp?prid=3844
Serpent
Old 03-15-2006, 07:57 AM   #7
Orfeous's Avatar
we will see how to do..
do you have that monoblock?
what radio and receiver are you using? and what battery charger?
is that connected to a power supply or are you charging from a car battery?
i have compared 2000 version with 97-99 version.
i saw that the point where frontshocks are mounted are little different.
then i didnt see anymore.. didnt compare them in detail
Old 03-15-2006, 08:41 AM   #8
M7H
M7H's Avatar
Yes, on my 950R
Graupner XS6 "synthesizer"
a simple Robbe multi charger 6
Plugged in the wall on 230V
That's about it, and the 2000 is aproxx. 6mm smaller on the rear tyres.....
Serpent
Old 03-15-2006, 02:20 PM   #9
Orfeous's Avatar
ok, what will the differneces be if i install a monoblock to my engine instead of the original two blocks?
Nice that you have a charger that you can connect to the 230V wall.. :P
seems that i must get an power supply from any manufactuer i dont like to always carrying a car battery everywhere.
i have a TEKIN BC112A
Ah, okey then i have found the differences.
I have no shocks mounted at the rear now.. and i tryed to flex the both sides.. it seems that the right side is lifting higher than the left side.. (view from front) is this normal or is it a setup issue?
How do i put in the driveshaft in the front? i just cant get them in haha..
what part must be removed?
i also found 3 screws that i dont know where to put.. i have reassembled the car.. and those screws are over.. hmm.
picture of them here... http://umea.mine.nu/~anton/gallery/m...&g2_itemId=372
Old 03-16-2006, 01:08 AM   #10
M7H
M7H's Avatar
As you can read in the link I gave You....
Better cooling (what you wanted)
Better motor protection....
Then you also buy one, they are not expensive....
If you have the right set-up tools, you can eliminate these kind of problems.....
If you unscrew the front bearingblock on the top or bottom side, this must I believe give you enough space to get them in....
Haha, nice......
But I have no idea......
Serpent
Old 03-16-2006, 07:25 AM   #11
Orfeous's Avatar
i have found a better charger than i have.. i have TEKIN BC112A
https://www.teamtekin.com/Manuals/BC112_96.pdf
the problem with that charger is that it only can handle NiCd batteries... but if i do an upgrade to software it can handle NiMh also.
so i think i will go for another charger instead.. that includes all kind of types batteries. Swallow Advance, it also got disscharge feature..
http://www.batterieswholesale.com/ba...ry_charger.htm
what do you think about that?
i found a power supply at 5A is that ok or is it little?
ok, what do you mean with "right setup tools" ?
ok, i will try to unscrew that parts
my order has comed today my new shockmembranes with foam inside
and the yellow springs and the pipemuffler mounting spring and silicon fuel lines (orange).
The strange is that the screws looks very shining.. they look nearly unsused.
i cant find that kind of screws in the manual either. i have looked at the car and searched for holes that have no screws but i cant find.. hm..
Old 03-16-2006, 08:43 AM   #12
M7H
M7H's Avatar
If it charges your batteries, it is good......
Ride height gauge, droop gauge, set-up system....
check:
http://www.hudy.net/flash_stuff/all_in/onroad/index.htm
and the in the 1/8 scale section......
Serpent
Old 03-16-2006, 01:45 PM   #13
Orfeous's Avatar
ok, i will go and buy that..
my friend has a setup system that i can borrow.. :P
Old 03-29-2006, 01:29 AM   #14
Orfeous's Avatar
i have now charged my RX and TX batteries with my new charger! it works wonderful! its so easy to manage.. just one button and you is charging hehe..
no hard menu's or something like that.
i putted the batteries in their places and turned all switches on and it worked hehe.. i'm impressed.
The thing i must do for the summer is to buy a new body.. a Lola
because it have better downforce than the porsche body.. but the porsche body is faster on long straights.
but i dont know what color to paint it it will be easiest to paint it one color.
maybe i should try our old airbrush
dont know if i told you that i found a swedish guy that was still competing with his Vector 97-99' so it seems it isnt just S960's out there.. :P but we are few with the vector
Old 04-17-2006, 06:26 PM   #15
Orfeous's Avatar
i cant understand why there are no old Serpent Vector drivers out there :P
someone should at least have been driven a vector?
i have no to talk with about it.
/Anton
1/8 Serpent Vector 2000 speedy100 R/C Items: For Sale/Trade 8 05-22-2006 02:02 AM
2000 Model Serpent Vector FS/FT Jackl R/C Items: For Sale/Trade 0 09-13-2005 06:46 AM
FS...Serpent Vector Sped 2000 6Cuda6 R/C Items: For Sale/Trade 2 02-01-2004 02:05 PM
Serpent Vector 2000 Vspec W/CMB 21 INFERN0 R/C Items: For Sale/Trade 10 12-02-2003 06:07 PM
Serpent Vector Nt 2002 Edition + Vector 2000 Pro Models R/C Items: For Sale/Trade 0 08-15-2002 08:12 PM
