Old 05-12-2006, 09:06 PM   #106
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
Is the hudy Bit a special one for the Integy lathe or does the standard Hudy Carbide Bit work? Anyone have a part number for it?
Jeff
Jeff Werner is offline   Reply With Quote
Old 05-13-2006, 07:24 AM   #107
Grenade10's Avatar
Trader Rating: 37 (100%+)
My 2 cents (racer for 15+ years)
If you really beleive that the Hudy is a much better unit, buy one that is used for 1/2 - 2/3 of the new price and you have spent the same money as if you purchased a new knock off.
If you beleive that the trueres are the same, but the new copy and be happy.
IMO - the best tire truer ever made was MaxMod - AC, Hudy can not even keep up with this on gas rubber. National race a few years back 1 working MaxMod, 8 or 9 dead Hudy's!!!
Down side they are no longer made, but a few still show up, like the one in my box!
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 05-15-2006, 10:36 PM   #108
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Jeff
Its the hudy carbide bit made for the hudy tire truers. It fits on the integy though but is short a couple of mm , I think -4.19mm to be exact. Maybe someone can verify my reading. So for example you set it at 60mm on the truer , itll true the tires to 64.19mm.
Part # HUD102067
Artificial-I is offline   Reply With Quote
Old 05-23-2006, 02:44 PM   #109
richey's Avatar
Send a message via MSN to richey
Originally Posted by Pyramid
Start shipping now...
GQ-TT02 ULTRA X TIRE TRUER "V2"
Competition R/C still dosent have these in stock, I hope they get them soon. this truer comes with a really cool carbide blade that is Patent pending
Silver Bowl Raceway Operator
www.TeamTaylorRacing.net
Byron's Fuel, Airtronics
JoshStevensFoundation.org
richey is offline   Reply With Quote
Old 05-23-2006, 09:57 PM   #110
Pyramid's Avatar
Yes, it cuts absolutely great in their first proto.
Pyramid is offline   Reply With Quote
Old 08-10-2006, 09:10 PM   #111
cdelong's Avatar
just somethig to think about guy's....
I was very unhappy with the power of my Integy Auto Truer, but liked everything else about it. I decided to buy a Hudy motor for it
Installing the Hudy motor does require some minor modifications.....
1). you have to remove the plate from the Integy motor and reuse it on the Hudy motor.
2). remove (unsolder) both of the Dean's plugs from the circuit board on the Integy truer.... they will not clear the larger diameter Hudy motor.
3). direct solder the motor and 12V DC input to the circuit board.
4). turn the ON/OFF switch upside down as it will not clear the motor.
5). remove the fuse holder and stuff it inside the case or remount it somewhere else as it will not clear the motor in it's stock location. I also recommend putting a 30A fuse instead of a 20A fuse in there.
So........ for $218 ($110 for the used Integy AutoCut Truer, $25 for a Hudy carbide bit and $83 for the Hudy motor) I have an Automatic truer that kicks but
It's a HUDY in Integy clothing
KYOSHO EVOLVA
35PLUS21
FUTABA 3PKS/KO PROPO
BYRON'S FUEL/TWISTER TIRES
cdelong is offline   Reply With Quote
Old 08-10-2006, 09:57 PM   #112
wallyedmonds's Avatar
Originally Posted by Artificial-I
Spent more time using the hudy carbide cutter on my integy. Works great. It clearly cuts better and does this in less time. Also from what Ive read you dont need to replace these? If so I think I found a winner.
i did this and i have a integy,but i went back to the hacksaw blades,the hudy wore out yes the hudy wore out,so now i just buy blades and cut them myself,i do change them alot tho to get a nice clean cut.
wallyedmonds is offline   Reply With Quote
Old 08-10-2006, 10:00 PM   #113
this is cool ya i think the integy dos not have the power,you have to cut a little at a time.
Old 08-10-2006, 10:48 PM   #114
cdelong's Avatar
the Integy has way too little power in it's stock form. The Hudy motor is 1/3 larger and is what Integy should have used to begin with. It just squeezs in the Integy case
It takes way too long when truing up 3- 4 sets of 1/8 th scale tires. I had to go 0.5mm - 1.0mm a pass to get a good finish with the stock Integy motor and a Hudy carbide bit. Now with the Hudy motor I can take 2- 3 mm a pass with no problem.
KYOSHO EVOLVA
35PLUS21
Old 08-10-2006, 11:03 PM   #115
Trader Rating: 69 (100%+)
great tip on the hudy/integy hybrid if im only truing 1/10 size foams, is this mod necessary?
marvi is offline   Reply With Quote
Old 08-10-2006, 11:59 PM   #116
razzor's Avatar
Any body try or used the HARD racing tyre truer?
http://www.hard-racing.com/productio...1029&pageNum=1
Just got mine and its vey good quality.
can do motor armatures as well with a add on module.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 08-11-2006, 06:52 PM   #117
cdelong's Avatar
The tires I'm truing are 35 shore only (1/8th On-road) and the Integy could not handle the fronts at all. If you are running 40/42/45 shore for 1/10th, I'd suggest the Hudy mod.
I also filled the stock fuse hole with an automotive undercoating plug to keep a clean look to the case. I epoxied a 30A circuit breaker inside the Integy case. It's an RV part from Borg Warner. If it happens to trip, it automatically resets itself after it cools down for a minute or so.
KYOSHO EVOLVA
35PLUS21
Old 08-11-2006, 07:50 PM   #118
Moderator
Another problem is the motor that scans across the bit , it also tends to lag and surge. Id figure that also gives the tires not such a great final finish.
Old 08-11-2006, 08:36 PM   #119
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
I've cut the front tires 37 shore for my 8th onroad and upto 40 shore for sedan tires on my Integy with no issue. As with any lathe for best finish I cut off some small layers at a time. If I want to do a deep cut I sorta trim little by little otherwise yes the motor will bog. I wouldn't try this with the Hudy either. I'm just going to get the Hudy blade for my truer and that's that.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 08-11-2006, 08:38 PM   #120
i only do 1/10 tires and i take my time and its fine,1/8 it will not do at all,and the hard looks sweet but i dont know how good it is.with the integy you just have to take your time.
MaxMod Tire Truer (large AC version w/adjustment for cutting camber into the tire) Danny-The-Dude R/C Items: For Sale/Trade 3 02-26-2007 03:10 PM
llooking for a hudy tire truer or an auto truer hpiaustin R/C Items: Wanted to Buy 2 12-09-2005 06:56 AM
Integy Tire truer, Arbors 1/10 and 1/12 plus carbide tire file evostyle R/C Items: For Sale/Trade 11 03-22-2005 11:58 PM
WTB Hudy Tire Truer Automatic or Other Tire Truer 993power R/C Items: Wanted to Buy 0 10-23-2003 05:47 PM
whats tire truer? sm64000 Electric On-Road 3 08-03-2003 08:10 AM
