Help me Out Dude
Old 12-09-2002, 10:26 AM
kilokhan's Avatar
Default Help me Out Dude
I got a Rs42 Robinson Ball-DIff.
I want to Clean it out what should/shouldn't do ?
Can i use WB-40 ?
kilokhan is offline
Old 12-09-2002, 10:33 AM
modellor's Avatar
WD-40 should be fine. It is designed for this purpose.
modellor is offline
Old 12-09-2002, 11:02 AM
eddiethefish's Avatar
I don't know much about Ball Diff. But, after the WD-40, should you reapply whatever Diff Fluid, Diff gel, Diff grease or whatever that is?
eddiethefish is offline
Old 12-09-2002, 11:37 AM
popsracer's Avatar
Default Ball Diff cleaning methods
Motor spray works great. You don't want the residue that WD-40 will leave. It is not compatable with the Silicone diff grease.
The best way is to disassemble, clean with Motor spray and reluble with the proper greases. Do this on a clean WHITE towel or rag so you dont loose the balls. I put mine in a White coffie cup for cleaning then dump them onto a White towel to wipe off.
popsracer is offline
Old 12-09-2002, 11:43 AM
kilokhan's Avatar
I get a Small Bottle
And Throw my (ball's)<------- u know wut i mean heheh
Close the bottle And shake it for a few minutes...
and then clean it with Towels and apply greese..
Btw wut greese should i use ?( i got a can of heavy duty greese)
But i guess it can't be use...
kilokhan is offline
Old 12-09-2002, 11:53 AM
popsracer's Avatar
Default WHAT GREASE!!???
Associated diff grease is supposed to be the best. Silicone (clear/white) for the diff balls and (black) for the thrust bearings/balls. Availible at your LHS.
