After run & lubrication oil for nitro engines >
Like Tree7Likes
Old 07-18-2019, 03:25 AM
  #16
Originally Posted by choisan View Post
i have been using mobil 1 or whatever remaining engine oil after i did the oil change every year for the last 20 years, never have any issue, never gummed.
I've heard from a couple of people that if the mystery oil is used without an engine cleaning then it's more likely to get gummed up over time. If it's gonna be stored away for years then it a better idea to strip down the engine and then apply after run oil/ATF/other types.
Personally I had got one used engine from eBay for $13 that was pretty tight and very difficult to turn. The seller did tell me that when he had put it away it still had good compression. When I took it apart the crack, piston, connecting rod etc had some greenish jelly like substance and the grease from the ball bearings had hardened into small pieces that it was moving around the crank and jamming it. Had to soak it first in WD-40 for a good couple of minutes and then only I could get it to start turning and then continued with the stripping and clean process.
NitroGod777 is offline
Old 07-18-2019, 04:56 PM
  #17
Bundy_Bear's Avatar
Engines should have caps over exhaust port, fuel nipple and carburetor to stop air getting in and drying out the oil when in storage. Would also put in air tight bag.
NitroGod777 likes this.
Bundy_Bear is offline
