Wrc Gtx
Old 04-01-2019, 03:56 PM
Default Wrc Gtx
can someone please help me? I bought the Wrc Gtx kit assembled it and canít for the life of me figure out how to set up the centax clutch! Iím running Picco R1 Engine I put the clutch together per instructions and it will not engage. Any help would be greatly appreciated
Donte1978 is offline
Old 04-01-2019, 04:57 PM
Super Moderator
1/8 IC Fan's Avatar
Trader Rating: 85 (100%+)
Is the bell free spinning? You may need to back off the spring retainer nut a bit to find the point of engagement. Keep in mind your clutch still needs to bed in, and may need further adjustment after
1/8 IC Fan is offline
Old 04-01-2019, 11:00 PM
Roelof's Avatar
Roelof is offline
Old 04-02-2019, 06:40 AM
Rick Vessell's Avatar
Watch the video that Roelof posted above. Michael explains step by step the correct process for building and setting the clutch.
Rick Vessell is offline
Old 04-02-2019, 02:27 PM
Roelof's Avatar
If you have builded the clutch right with all the needed parts then the gap is set too high and/or the spring is scewed too tight.
Roelof is offline
Old 04-03-2019, 11:40 PM
When i first built my gtx clutch i had screwed in the spring much to far...probably the same issue for you.
dusted 2 shoes before it clicked
jtrmx250 is offline
