I can restore old worn piston/sleeve sets for $15.00
#17
This sounds like someone is stealing John Bohland's idea and trying to capitalize on it! John, or OSRocket on E-bay and S-grid has been doing this for a year or more after much research and hard work and now he has perfected it , every shadetree hack wants in on it and will probably ruin it for everyone. John's stuff is spot on and after 20 piston and sleeves I should know! He uses a CNC hydraulic tubing crimper which is way more accurate than a lathe collet !
#19
waaaazzzzuuuuuuup
Man this is unbelievable, for $15.00 if it works it works, if it doesn,t the guy will give you your money back, and hey the parts were screwed anyway........what is your problem?
Squeeze, good luck with the venture.I wish you all the best.
gt
gt
#20
Give the guy a break! If someone tries it and believes its junk then I'm sure they will come back and tell everyone ........where I'm from your are innocent until proven guilty...not the other way round! and as sqizzytaylor says...what you are sending out is 'junk' anyway!!
How do you think John Boland started in the first place???
#22
i was only egging him on so i could see his machine for 15 bux, i would do it even if it lasted a few race meets
#23
Location: 4373 Creek Road Chaffee,NY 14030 USA (716)783-5198
Trader Rating: 23 (100%+)
One Mans Junk Is Another Mans Treasure
This is the additude that has got my goat right from the get go. A worn piston/sleeve set that ranges from say $60 for a (.12)novarossi line thru $200 for a RB with Mods...IS NOT JUNK! That is old school mentality.... Welcome to the real world of RC. Guys with a racing budget can and should be able to afordabley rebuild their engines with maintaning original performance/reliability. How one values their possessions is their own choice. Wake up call boys....you will find more rc guys than not that would be very sensitive to a being told "I couldn't fix it...something went wrong...It was junk anyway". I build things and repair things with values of $100 thru $100,000 Pluss. In any instance, I do not allow myself the option to pass off my mistakes to a costumers expense. I to have limitations...I recognise them....I can't do the job right, I will send the job down the road. My personal profile is open domain . Unlike squeezy here my name will remain the same. And "asd" I,m 80 miles from toronto should you wish to see researched and developed. Hope I did,t sound like as big a P...k as i realy am. He He
#25
#26
#27
Re: This is fun now..Check out his other forum
Originally posted by pre1960
http://www.rcnitrotalk.com/forum/sho...5&pagenumber=3
#29
With a "squeezed" piston and sleeve, you almost always have to replace the rod. The fit has to be so tight to produce good results that it puts major strain on the rod bushings. Plus the original rod is worn anyway.
