Old 12-03-2002, 07:19 PM   #1
Default Fuel Filter?
I was wondering, does fuel filter help alot or its just a place to
place extra fuel?
Plz reply.....THX
[HPI]RS4SS is offline   Reply With Quote
Old 12-03-2002, 07:44 PM   #2
modellor's Avatar
There is more than likely a fuel filter built into your tank.
External fuel filters in my opinion just upset the running of the engine.
My 2 cents.
modellor is offline   Reply With Quote
Old 12-03-2002, 08:34 PM   #3
nitrodude's Avatar
I used to run one and my engine was always overheating. The guys at the track said take it out and tune your engine again. Well, my engine doen't overheat anymore amd it runs great.
Steven Muller
nitrodude is offline   Reply With Quote
Old 12-03-2002, 08:36 PM   #4
InitialD's Avatar
My 2 cents.
That is correct. Most people nowadays use the fuel filter at the pressure tubing from the pipe to the tank instead to ease out pressure variations and maintain constant pressure.
Old 12-08-2002, 07:11 PM   #5
Tech Chat Moderator
TheRagunCajun's Avatar
Default in-line fuel filter
They do serve a purpose thats is to clean the fuel going into the engine. Like they said their might be a built in fitter in the tank. Also if you do run the filter you have a chance of it leaking and if that happens it can hurt your engine. It would run very hot and crazy. I bought one but i took it off right away. I never heard of it being used on the pressure line but it makes sense why. I use 12" of pressure tubing to make my car run properly. This is my pride and joy in the link below. BTW i just ordered about $400 worth of hop ups for it today .
Wow these forums have gotten popular since 02!
TheRagunCajun is offline   Reply With Quote
Old 12-08-2002, 09:27 PM   #6
popsracer's Avatar
Default Fuel Filters exposed
[HPI]RS4SS
If your tank ALREADY has a Bronze filter inside of it, then there is no reason to add another. If it doesn't then you SHOULD add one to the fuel line from the Tank to the Carb. The Filter keeps small particals of dirt from getting inside your Carb or Engine. USE ONE!
TheRagunCajun;
12" of any line on your R/C is WAY too much. The longer the line the MORE resistance to whatever you are trying to move in that line. ONE loop in your Pressure line should be enough 6-8" MAX.
Keep you fuel line as short as possible or it will effect engine tuning drasticly.
popsracer is offline   Reply With Quote
Old 12-08-2002, 09:32 PM   #7
popsracer's Avatar
Default My 8 yr old Son's HPI Nitro2
This belongs to my 8 yr old Son, Michael. Last two weekends in a row he got 1st place in the Nitro Rookie class at our local tracks.
Old 12-08-2002, 10:20 PM   #8
ChrisO's Avatar
Send a message via AIM to ChrisO Send a message via Yahoo to ChrisO
good on him!
ChrisO is offline   Reply With Quote
Old 12-09-2002, 10:33 AM   #9
Tech Chat Moderator
Default Re: Fuel Filters exposed
[i]TheRagunCajun;
Keep you fuel line as short as possible or it will effect engine tuning drasticly. [/B]
Thanks for the advice. I'll try about 7" when i get my goodies in and my car running again. Tuning isnt really a problem, but i do understand what u mean and you are correct. BTW nice nrs4 in the pic
Old 12-09-2002, 10:59 AM   #10
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
Hmm... This is really good to know. I'll shorten my fuel tube and make sure the pressure tube is about 7" long.
eddiethefish is offline   Reply With Quote
Old 12-09-2002, 11:46 AM   #11
popsracer's Avatar
Default Nice Set-up
Eddiethefish;
Nice Mugen. I would leave the Fuel line alone, It looks fine. The pressure line if shortened will make your engine more responsive. Sometimes guys will run long lines on off-road to tame down the engine and to keep more fuel in the line in case of a rollover. It is not really needed for on-road.
Old 12-09-2002, 11:59 AM   #12
Default Re: Nice Set-up
Originally posted by popsracer
Eddiethefish;
Hello popsracer,
Your Reflex looks so clean, have you run it at all? Thank you for the advice. I'll shorten the pressure line, definitely.
Old 12-09-2002, 10:30 PM   #13
popsracer's Avatar
Default RUN IT AT ALL!!! are you kidding?
Mr. FishtheEddie
If I don't race EVERY weekend I start going through Nitro Withdrawls and get REALLY cranky!.
I raced an HPI Nitro2/Racer2 (My Son still has one). for about 2 years before getting my Reflex. I've had my Reflex for about a 1 yr now and I wouldn't trade it for anything. Total Reflexes in the Familiy is (4).
And I really do race every weekend (on/off-road) and it's easier to work on when clean.
Heres our pit this last Sunday. (not me in the picture)
Old 12-09-2002, 10:51 PM   #14
Manticore's Avatar
R/C Tech Charter Subscriber
Check here for the tech tips about line length from the engine master
Manticore is offline   Reply With Quote
Old 12-09-2002, 11:17 PM   #15
Thank you MantiCore, I'll shorten mine to 8" then
What Fuel Filter? Captpete Nitro Off-Road 2 07-27-2008 10:24 PM
LST2 fuel filter mcc Monster Trucks 2 10-17-2007 11:57 PM
Run with or without a fuel filter? GHETTOTEACHER Nitro Off-Road 5 08-14-2007 08:50 AM
Fuel Filter? customride Rookie Zone 11 05-27-2007 02:51 PM
fuel filter and air filter GReddy Electric Off-Road 1 07-10-2004 08:04 AM
