Old 12-11-2002, 09:56 AM   #31
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
popsracer recommends 6"-8"
Manticore recommends 8"-12"
Mine is 8" now, so I'm ok...
eddiethefish is offline   Reply With Quote
Old 12-11-2002, 10:18 PM   #32
popsracer's Avatar
Default Now that's a logical man!
Eddie;
I like your way of thinking.
Have you raced your car with the longer pressure line? You WILL notice the difference if you have.
popsracer is offline   Reply With Quote
Old 12-11-2002, 10:30 PM   #33
popsracer's Avatar
Default Fuel line to the Carb lengths
Jason; (My fingers are tired tonight)
MY OPINION:
If you wrap or run the fuel supply line/tubing next to, around, close to the cylinder head. The heat from the Cylinder Head is going to heat up that fuel and reduce power output.
From past experience, I've found it is better to keep the fuel suppy line as short as possible. On-Road cars are not supposed to be on there lids very often and that would be my only reason for running a longer line.
Old 04-16-2005, 10:54 AM   #34
GReddy's Avatar
Send a message via AIM to GReddy
can anyone tell me the effects of a long pressure line over a short pressure line?
GReddy is offline   Reply With Quote
Old 06-14-2005, 10:07 PM   #35
Dragon's Avatar
Send a message via ICQ to Dragon
Hey guys, i just got a fuel filter for my Vone S III, and i have mounted it on the fuel line between the tank and carb.
However i see many cars having theirs betweent he pipe and tank... what good does that do?
I read earlier that it overheats the tank... how? it doesnt seem that it would logically affect anything to me... unless it gets clogged up and restricts fuel flow, thus engine runs leaner??? but thats good right? it means tat it works, and dirt isnt getting into your engine?
Dragon is offline   Reply With Quote
Old 06-15-2005, 12:01 AM   #36
factory racer's Avatar
popsracer;
I can see ur point in using as short as a fuel line as possible....and you do say that the only reason for running a longer fuel line would be for off road truck.....that is not so.....many racers run long fuel lines, not for the sake of flipping the car on its hood and so it doesnt stall....but some do it to get more time per tank........long fuel line means that the car can hold more fuel in it which means that the car will run longer before having to pit in and refuel
just my $0.02 about that fact....
Mike
factory racer is offline   Reply With Quote
Old 06-15-2005, 08:53 AM   #37
Dragon's Avatar
Umm... is this right? So confusing... i just installed it...
I dont even dare to start my car now... after reading what u guys said earlier..
What Fuel Filter? Captpete Nitro Off-Road 2 07-27-2008 10:24 PM
LST2 fuel filter mcc Monster Trucks 2 10-17-2007 11:57 PM
Run with or without a fuel filter? GHETTOTEACHER Nitro Off-Road 5 08-14-2007 08:50 AM
Fuel Filter? customride Rookie Zone 11 05-27-2007 02:51 PM
fuel filter and air filter GReddy Electric Off-Road 1 07-10-2004 08:04 AM
