Infinity IF15 200mm Nitro Tourer >
Like Tree23Likes
Old 08-27-2019, 05:53 AM
  #91
Originally Posted by TomasRC View Post
I have the setup sheet on whatsapp too...
But which item do you need?...
Hey there Tomas,
I am after the following from JG setup sheet:
shock springs and pistons front and rear
anti roll bar - front and rear
ride height - front and rear
front - toe out, camber, castor, downstop
rear - toe in, camber, rear hub spacer, downstop
thanks,
Sam
sambrad is offline
Old 08-27-2019, 09:33 PM
  #92
bigbank66's Avatar
Yeah....u cant read it when u blow it up???
bigbank66 is offline
Old 08-28-2019, 02:42 AM
  #93
no mate, its too blurry when you blow it up, or maybe its just my eyes lol
sambrad is offline
Old 08-28-2019, 03:48 PM
  #94
THE FRIDGE's Avatar
Default Sorr
Originally Posted by sambrad View Post
Hey there Tomas,
thanks,
Sam
Hey Sam
shock spring - front serpent red short spring with 2 hole piston. Rear is serpent red long spring with 2 hole piston with infinity 550cst oil front and rear.
Roll Bars - front 2mm rear 1.9mm
Ride height - 7mm front and 8mm rear
front - toe out 1, caster 4, camber 1, downstop 0
rear - toe in 3, rear hub spacer 2mm, camber 4, downstop 4.
hope this helps
happy racing
Clint
THE FRIDGE is offline
Old 08-28-2019, 07:11 PM
  #95
Originally Posted by THE FRIDGE View Post
Hey Sam
hope this helps
happy racing
Clint
Hey Clint,
Legend, just what I was after!
Thanks,
Sam
sambrad is offline
Old 08-28-2019, 10:27 PM
  #96
bigbank66's Avatar
Money👌🏾
Old 09-02-2019, 07:46 AM
  #97
Hey there Tomas,
thanks,
Sam
Hi Sam, here is the info I got:
- shock config: serpent red front and rear, piston std with 2mm hole
- Antiroll bar: 2mm at front and 1.9mm rear
- Ride: 7mm front - 8mm rear
- toe: 1 front - 3 rear
- camber: 1 front - 4 rear
- caster: 4mm spacer at rear
- downstop: 0 at front / 4 at rear
- rear hub spacer: 2mm
I hope this could help you!
TomasRC is offline
