Infinity IF15 200mm Nitro Tourer >
Like Tree23Likes
Old 07-09-2019, 10:21 PM
  #76
Originally Posted by NITTO550 View Post
Are there any optional springs for this car?
At the moment there are no other springs from Infinity, I have run diferent tracks with stock just play with damping oil, other springs I see the top drivers try are serpentís and SMJ if Iím not mistaken! Hope this helps
FrancoM is offline
Old 07-17-2019, 09:37 AM
  #77
bigbank66's Avatar
The stock springs work well wit the car....I have tried serpent springs also if needed
bigbank66 is offline
Old 07-22-2019, 12:48 PM
  #78
bigbank66's Avatar
Default Set ups
Has anyone found a set up from the pros like Leno or Moore for there cars....something besides the worlds setup....can u post up somethin??
Old 07-28-2019, 12:50 PM
  #79
Hi guys!, Jilles G. has recently post a new setup
TomasRC is offline
Old 07-28-2019, 06:59 PM
  #80
bigbank66's Avatar
Can u post a link....I cant read this one....thanks
Old 07-28-2019, 07:23 PM
  #81
THE FRIDGE's Avatar
it's on facebook that Jilles posted it I got him to send me a copy which is a bit better but still not 100% clear I can whatsapp it to you just pm me your details and I'll send it over. But it should be to long and they will be up on the infinity web site.
Cheers
THE FRIDGE is offline
Old 08-04-2019, 02:57 PM
  #82
I have the setup sheet on whatsapp too...
But which item do you need?...
TomasRC is offline
Old 08-14-2019, 03:50 PM
  #83
Default Diff oil fron & rear for a low grip track?
Hi Guys,
What diff oil do you recommend for the front and rear on a low grip track?
JasonM246 is offline
Old 08-14-2019, 06:13 PM
  #84
THE FRIDGE's Avatar
Originally Posted by JasonM246 View Post
Hi Guys,
300k front 60k rear
Old 08-14-2019, 06:15 PM
  #85
Hi Guys,
Hi Jason, I thinks the best way to go is using 1 to 2.5 million in the front for a smoother car, and 50k or 60k the most in the rear! Hope this helps! Any other information you need donít hesitate to ask!
FrancoM is offline
Old 08-15-2019, 07:29 PM
  #86
Originally Posted by THE FRIDGE View Post
300k front 60k rear
thanks!!
Old 08-15-2019, 07:31 PM
  #87
ok......thanks FrancoM. I will let you know how it goes!
Old 08-15-2019, 07:50 PM
  #88
bigbank66's Avatar
I think u will like 500k the best....I think 1mill is still 2 high for low bite....50 or 60 is a great start...
Old 08-17-2019, 04:19 PM
  #89
ok....i will test 500 as well
thanks
