Serpent 750 Natrix >
Serpent 750 Natrix
Like Tree34Likes
Serpent 750 Natrix
Old 01-13-2022, 10:19 AM
  #166
HK500Pilot's Avatar
Originally Posted by lil-bump View Post
You purchased a pipe with a straight header rather than a curved header. Some say the straight header gives better fuel milage. in any case it should fit the car. I would go back to the stock hanger and slightly angle the pipe so the front of the pipe is closer to vehicle. Just make sure you do not have an exhaust leak at the joint where the pipe meets the header. Your may have to massage into place but it will fit. If your body was already cut for a different style pipe you will have to modify your exhast hole to fit the new pipe.
Thank you very much for the reply, I really appreciate it.
Thank you for clarifying that I can still use the pipe I originally purchased. I just hadn’t seen too many pipes angled over like you mentioned was possible to do with this manifold / exhaust set up.
Thanks again for your help......
HK500Pilot is offline
Old 01-13-2022, 07:07 PM
  #167
TeamCarnage's Avatar
Trader Rating: 30 (100%+)
Good advice from Elliot. That pipe and header combo should work well. You really need to reroute your plug to the other side of the car.. my .02. Good Luck finishing it all up.
TeamCarnage is offline
Old 01-13-2022, 07:43 PM
  #168
HK500Pilot's Avatar
I appreciate the .02 cents Carnage. What plug are you speaking of?
Old 01-19-2022, 02:28 AM
  #169
Julius's Avatar
I think he refers to the battery plug. The position it is in now puts it at risk of being eaten by the belt. Normally the plug is positioned close to the receiver. That makes it easier to connect and disconnect with the body on. Now I would not dare with the hot pipe close to the plug…
But in any case route the wire to come up between the tank and the radioplate. That will keep it away from the belt and pipe more than it is now.
with the straight header I do advise you to stick some aluminum tape onto the inside of the body. Otherwise it will melt from being pressed into the header by the airflow during driving.
TeamCarnage likes this.
Julius is offline
Old 01-20-2022, 12:06 AM
  #170
Default Rear tires touching rod
Tires touching toe in rod.
hey guys just wondering why my 30mm matrix tires are touching the end of the toe in rod?
codslayer is offline
Old 01-20-2022, 12:22 AM
  #171
It’s the bottom rod under the gears.
Old 01-20-2022, 04:11 AM
  #172
All good! Got it now, had the camber mounts on the wrong way 😂
Old 01-22-2022, 08:30 AM
  #173
Julius's Avatar
yep. You’re not the first. Nor will you be the last 😂
Julius is offline
Old 02-08-2022, 08:13 PM
  #174
HK500Pilot's Avatar
Ok so I “massaged” the One brand header and pipe into the best place possible without getting any type of exhaust leak. I started the engine up today and felt around the header where it mounts to the engine and couldn’t feel anything slipping by the rubber joint.
Esthetically it just doesn’t please me all crooked like it is. I’m actually looking for different header and pipe combos to replace the one I have. The pipe and header I currently have are very study with the factory pipe mount.
So I may replace this pipe/header in time if I can find the right set up.
I have moved the wiring around in order to get that better situated in the area of the belt, it is just not shown in this picture
Old 02-10-2022, 10:47 AM
  #175
TurnNBurn's Avatar
Anything to look out for in particular? Is it an error in the manual, or just a build step that is widely misunderstood? I’m FINALLY looking to build mine in the coming weeks (Ugh - long story),so any tips or advice is appreciated.
TurnNBurn is offline
Old 02-10-2022, 07:53 PM
  #176
HK500Pilot's Avatar
You got this, you will be fine, just pay attention to what your doing. The routing of the servo and battery wiring was an area I struggled with.
Old 07-21-2022, 01:07 AM
  #177
Default 750evo
Hi guys, do you have problems with the rrs system?
is it safe for a regular user? I saw some photos of 750evo with the wishbones of 750natrix..
thanks!
brosla7 is offline
Old 07-21-2022, 02:21 AM
  #178
thanks!
I have only been racing since the start of the year and a few of the experienced guys at my local track directed me to use the regular 750 natrix rear suspension. I have found it really beneficial as being a somewhat beginner I was always breaking the rear lower arms and other rear suspensions parts. I found the older arms more rigid and stable and haven’t had any broken parts yet.
Old 07-21-2022, 04:19 AM
  #179
Suspended
Yes, I sometimes have problems with the rrs system .
RYoung is offline
Old 01-26-2023, 07:25 AM
  #180
Does anyone know if Serpent will come with an 235mm model or kit for the 750?
Pertn is offline
