Starterbox Questions
Ok, I've got my car already, but the flywheel isn't moving wen applied to the starter box wheel. I've checked the alignment many times and made sure it is perfect but that wheel just won't move. Any ways you guys know to line it exactly.
is the engine stuck at TDC
if it is stuck at tdc then use a flat bladed screwdriver and pry it aginst the chassis and the flywheel and use it as a lever to turn the engine over.
Thanks,
Engine was stuck at TDC, but hadn't fully got to TDC so i took it out and rotated.
