Old 11-28-2002, 12:56 PM   #1
Send a message via AIM to ProRacer03
Default Engine Question...
I just cleaned out a motor an RS .12 that I just picked up. I had a question about the motor turning over, it seems like it's not turing over smootly.
Should it turn over smoothly? or should it be tough at about TDC or BDC?
Still a newbie but still learning too. Seems pretty fun to open up and clean a motor.
Any helpful hints on cleaning the bad boy?
ProRacer03 is offline   Reply With Quote
Old 11-28-2002, 01:21 PM   #2
tennessee's Avatar
Is it a brand new motor or used?
Have you broken the motor in?
When you took it aprt ,did you lube the parts before you put it back together?
Did you put the piston in backwards?
tennessee is offline   Reply With Quote
Old 11-28-2002, 11:56 PM   #3
The motor is a new motor. I am cleaning the internals accoring to the instructions.
I lubed it w/ fresh fuel to clean and lub the internals. The first time in installed the piston backwards but I put it back to the right way.
After I replaced everything it seems like when i put on the head the crank is hard to turn over. it seems to lock on something. Then when I open up the head to inspect if anything is rubbing there a ring of sut around the top of the sleeve.
I'm not sure if it is supposed to be tough to turn the motor once i put everything back together lubed or is it supposed to be smooth?
Old 11-29-2002, 12:09 AM   #4
popsracer's Avatar
Default Tight Engine
Proracer03;
A new engine can and will be VERY tight at TDC. This is due to the fit of the piston and sleeve and is normal.
Buy some after-run oil for lubing your engine. (Marvel Mystery oil)
Fuel will attract moisture and can cause the internals of your engine to rust.
It will probally take a quart of fuel before the engine starts to loosen up some. Make sure the piston is at BDC when you stop running. If it stops at TDC and then cools down, it can be almost impossible to unstick the piston in the sleeve without causing some kind of damage .
popsracer is offline   Reply With Quote
Old 11-29-2002, 09:03 PM   #5
tennessee's Avatar
We must be on the same page pops because alot of people don't even think about doing that after they run they're motors 1/8 or 1/10
Old 11-29-2002, 09:18 PM   #6
popsracer's Avatar
Default Tight Pu.. Err, Engines
Tennessee;
It's amazing how much abuse you see/hear about on engines. It's funny, I WAS going to say that a little common sense goes along way. BUT really engines and motors can be scary stuff for the average person to deal with. I guess you and I are lucky to have it in our Genes.
Proracer03;
I try not to disassemble an engine unless it is absolutely nessesary. A teeny-tiny piece of dirt could ruin a $150-200 engine in a minute and most people just don't realize this. Go to the HPI website and review the "Engine Horror Stories" and you'll see what I mean.
engine question and radio question alucard13 Nitro On-Road 12 09-12-2008 09:21 AM
.21 Engine Question roylo Nitro Off-Road 7 09-03-2007 11:04 PM
General .21 engine question as well as one specific to Sportwerks .21 Pro engine Cain Electric Off-Road 0 10-23-2006 11:19 AM
Nitro engine question - newbie question. BloodClod Singapore R/C Racers 6 09-11-2002 10:33 AM
Serious gas engine question. pro engine tuners look here Ron Nitro On-Road 28 11-13-2001 04:27 PM
