Old 02-04-2006, 08:17 PM   #1
Default Need help with Brake in
Hi everyone! I need some help with Brake in my engine.
I have a Vega .12 3 port. I believe it is Italian made. In the manual says that I should use 10 to 15% percent fuel, and I am using 10%. Also it says that for brake in, I should open the main neddle 1.5 turns, and it doesnt say anything about the low speed needle. The carburator come with the low speed needle closed. The thing is that I tried to start the engine as the manual says, but engine doesn't start. I tried to open more both needles, and the engine starts, but stalls when I accelerate. When I open the main needle 5 or 6 turns, the engine seems to respond, but it stalls after one minute or less when I accelerate. It seems that there is a lot of smoke from the exhaust, but I dont see oil coming out. I dont know what to do! Please, help!
Sorry for my English, but I am an international student in Seattle, and my English is still bad, after four years!! Thank you very much.
TomiRC is offline   Reply With Quote
Old 02-04-2006, 09:43 PM   #2
rcabj's Avatar
u should try the engine zone....i think there's a couple threads on how to break in an engine...good luck
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 02-05-2006, 01:04 AM   #3
Thank you
Old 02-05-2006, 10:18 AM   #4
Actually I forget to mention that in the manual says to open the main fuel-mixture needle for 1.5 turns (ONLY DURING RUNNING-IN OF THE ENGINE).
How is it possible? should I leave the main needle closed after I have finished the brake in??
Old 02-05-2006, 01:08 PM   #5
first set it to factory tuning,
turn it on let it idle for one tank
second tank drive slow
3d check the temp it shud be between 200 - 250
4th drive the it a lil faster
5 drive half speed ( check temps )
6 fast for 2 tanks ( check temps ) continued untell 11th tank.
Hope this helps
Modifiedrs4evo3 is offline   Reply With Quote
HELP - How to BRAKE - IN savage600 Indonesia Racing 47 08-01-2006 06:22 AM
brake help ceraf Rookie Zone 1 05-30-2006 01:35 PM
ECS- Auto brake/Neutral Brake/Drag brake RC12L3a Electric On-Road 6 11-21-2004 10:10 PM
brake SUper nitro dud Minnesota and North/South Dakota Racing 6 09-10-2004 04:01 PM
drag brake, brake and reverse imjonah Rookie Zone 3 07-24-2004 07:20 PM
