Old 02-04-2006, 12:53 AM   #1
maskedrider's Avatar
Default Dented
dented pipe can be fixed???
Kyosho- Sirio/ OS engine- AVID bearing- Blue thunder fuel- Proline- RC dynamite- Sanwa- RC Art
maskedrider is offline   Reply With Quote
Old 02-04-2006, 01:36 AM   #2
Xyvern's Avatar
Yes, try using the heatgun.
Xyvern is offline   Reply With Quote
Old 02-04-2006, 02:00 AM   #3
AndyT 's Avatar
If your pipe is dented try "freezing" the dent out.....to do this-
1. Remove pipe/header etc from car
2. Close off the pressure outlet (i use old fuel tube kinked over and cabled tied)
3. Close of the stinger....cling wrap and elastic bands work
4. Fill the large end with water, and then place the pipe in the freezer......check every 20 minutes or so.....the water will freeze and expand and hopefully push the dent out. Make sure you check every 20 min`s or so that it doesnt over expand.
Hope this helps
Cheers
AndyT  is offline   Reply With Quote
Old 02-04-2006, 03:05 AM   #4
TT120's Avatar
Send a message via ICQ to TT120
The freezer trick does work. I've done it several times. You may have to do it 3 or 4 times to get most of the dent out.
TT120 is offline   Reply With Quote
Old 02-04-2006, 03:58 AM   #5
can this dent can be 'freezing' out ?
Old 02-04-2006, 10:05 AM   #6
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Thumbs up
Should be no problem.
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 02-04-2006, 10:15 AM   #7
hopefully it can be fixed
Old 02-04-2006, 07:57 PM   #8
AndyT 's Avatar
If its dented like this, i try and straighten the stinger area out by inserting a screwdriver (or similar) into the stinger and levering it into shape a bit.
If you use some metal putty (in future pipes) to put around the stinger area to build it up, this should help prevent damage.
Cheers
Old 02-04-2006, 08:24 PM   #9
Cheers
i had tried using screwdriver to lever it but seems it quite difficult.
i now using the freezing method to see if works
Old 02-04-2006, 08:39 PM   #10
Dreddlox's Avatar
Dont do it while the pipe is cold, it may crack at the seam. Warm the pipe up and then bend. It will go into place with no problem.
Dreddlox is offline   Reply With Quote
Old 02-04-2006, 10:51 PM   #11
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Next time this happens, try to do this when you realize its dented. It should happen after you ran your car, which means the pipe will be at operating temperature and it would be easy to pull it with plyers.
Riketsu is offline   Reply With Quote
Old 02-05-2006, 12:05 AM   #12
hav_lova's Avatar
After you fix the dent put some kneadit on the stinger so it doesn't happen again. its a 2 part putty its the shizne!!
Just playing with bigger toys now...
serpentrc.com.au
hav_lova is offline   Reply With Quote
Old 02-05-2006, 04:01 AM   #13
getting better after first freezing, hopefully after doing several time to get the orginal shape out. Will post the result after completed.
Old 02-05-2006, 04:30 AM   #14
quick little addition to the freezing. You need to seal it up completely so it doesn't expand out the openings. I use tubing on the stinger with a bolt in it and on the coupler side and two piece pipe coupler with a bolt in it. it will take alot less times of freezing
Dan D is offline   Reply With Quote
Old 02-05-2006, 04:40 AM   #15
hmm.... me only used tubing on the stinger and the rest used only plastic bag tie with a rubberband....hope i using the right way
Dented Pipe?? NitroMaxx3.3 Nitro On-Road 23 07-18-2007 05:28 PM
Dented Carb..Help jetbill007 Onroad Nitro Engine Zone 3 01-18-2007 01:03 PM
how to fix a dented pipe uniquexme Nitro On-Road 12 08-30-2006 08:31 PM
Reforming dented dual-chamber pipes? chachi Nitro On-Road 10 05-15-2003 12:32 AM
